[Swift-devel] Re: coaster error on ranger
Zhao Zhang zhaozhang at uchicago.edu
Thu Jun 11 13:04:42 CDT 2009
No, I don't specify any wall time.
The last entry is for the run_ampl script.
zhao
login3% cat tc.data
#This is the transformation catalog.
#It comes pre-configured with a number of simple transformations with
#paths that are likely to work on a linux box. However, on some systems,
#the paths to these executables will be different (for example, sometimes
#some of these programs are found in /usr/bin rather than in /bin)
#NOTE WELL: fields in this file must be separated by tabs, not spaces; and
#there must be no trailing whitespace at the end of each line.
# sitename  transformation  path   INSTALLED  platform  profiles
bgps    echo            /bin/echo       INSTALLED       INTEL32::LINUX  null
bgp000  cat             /bin/cat        INSTALLED       INTEL32::LINUX  null
localhost       sleep           /bin/sleep      INSTALLED
INTEL32::LINUX  null
localhost       echo            /bin/echo       INSTALLED
INTEL32::LINUX  null
localhost       ls              /bin/ls         INSTALLED
INTEL32::LINUX  null
localhost       wc              /bin/wc         INSTALLED
INTEL32::LINUX  null
localhost       grep            /bin/grep       INSTALLED
INTEL32::LINUX  null
localhost       sort            /bin/sort       INSTALLED
INTEL32::LINUX  null
localhost       paste           /bin/paste      INSTALLED
INTEL32::LINUX  null
localhost       date            /bin/date       INSTALLED
INTEL32::LINUX  null
localhost       db              /home/wilde/angle/data/db
localhost       set1            /home/wilde/angle/data/set1
localhost       set3            /home/wilde/angle/data/set3
localhost       run_ampl
/share/home/00946/zzhang/SEE-work/static/run_ampl   INSTALLED
INTEL32::LINUX  null
tgtacc       run_ampl
INTEL32::LINUX  null
Mihael Hategan wrote:
> Your jobs seem to not have a walltime specified. Can you post your
> tc.data?
> On Thu, 2009-06-11 at 10:37 -0500, Zhao Zhang wrote:
>> Hi, Mihael
>> The coaster log is at /home/zzhang/see/logs/coasters.log. The latest
>> record should be the run that failed last night.
>> best
>> zhao
>>> On Thu, 2009-06-11 at 09:24 -0500, Zhao Zhang wrote:
>>>> Hi, Mike and Mihael
>>>> Here is the error, I think this is related to the job wall time of
>>>> coaster settings.
>>>> Mihael, could you give me some suggestions on how to set the parameters
>>>> for coasters on ranger?
>>> I need to know what the problem is first. And for that I need to take a
>>> look at the coaster log (and possibly gram logs). So if you could copy
>>> that to some shared space in the CI, that would be good.
>>>> For now I am running 100 jobs, each job could take 2~3 hours. Thanks.
>>>> best
>>>> zhao
>>>> Execution failed:
>>>>         Exception in run_ampl:
>>>> Arguments: [run70, template, armington.mod, armington_process.cmd,
>>>> armington_ou\
>>>> tput.cmd, subproblems/producer_tree.mod, ces.so]
>>>> Host: tgtacc
>>>> Directory: ampl-20090611-0122-hzktisu5/jobs/h/run_ampl-h92ap3cj
>>>> stderr.txt:
>>>> stdout.txt:
>>>> Caused by:
>>>>         Shutting down worker
>>>> Cleaning up...
>>>> Shutting down service at https://129.114.50.163:58556
>>>> And here is my sites.xml
>>>> bash-3.00$ cat tgranger-sge-gram2.xml
>>>> <config>
>>>>   <pool handle="tgtacc" >
>>>>     <gridftp  url="gsiftp://gridftp.ranger.tacc.teragrid.org" />
>>>>     <execution  provider="coaster"
>>>> url="gatekeeper.ranger.tacc.teragrid.org" jobManager="gt2:gt2:SGE"/>
>>>>     <!-- <profile namespace="globus"
>>>> key="project">TG-DBS080004N</profile> -->
>>>>     <profile namespace="globus" key="project">TG-CCR080022N</profile>
>>>>     <workdirectory >/work/00946/zzhang/work</workdirectory>
>>>>     <profile namespace="env"
>>>> key="SWIFT_JOBDIR_PATH">/tmp/zzhang/jobdir</profile>
>>>>     <profile namespace="globus" key="coastersPerNode">16</profile>
>>>>     <profile namespace="globus" key="queue">development</profile>
>>>>     <profile namespace="karajan" key="initialScore">100</profile>
>>>>     <profile namespace="karajan" key="jobThrottle">10</profile>
>>>>     <profile namespace="globus" key="slots">20</profile>
>>>>     <profile namespace="globus" key="lowOverAllocation">5</profile>
>>>>     <profile namespace="globus" key="highOverAllocation">1</profile>
>>>>     <profile namespace="globus" key="maxNodes">5</profile>
>>>>   </pool>
>>>> </config>
