[Swift-devel] block coasters not registering on proper queue
Mihael Hategan
hategan at mcs.anl.gov
Mon Jun 8 17:49:25 CDT 2009
On Mon, 2009-06-08 at 16:24 -0500, Allan Espinosa wrote:
> Is there a default maxwalltime being submitted to the LRM if nothing
> is specified?
The block maxwalltime varies depending on the job maxwalltimes and the
overallocation parameters. So in a sense, yes.
> I made in this configuration to use the "fast" ueue in
> sites.xml but i keep getting placed inside the "exteneded" queue.
My gut feeling tells me that the LRM would not change the queue if the
walltime didn't fit, but would instead complain that the maxwalltime is
larger than what the queue accepts. So it looks more like the queue
parameter doesn't get passed to the LRM properly.
> sites.xml
> <config>
> <pool handle="teraport" >
> <gridftp url="gsiftp://tp-osg.ci.uchicago.edu" />
> <execution provider="coaster" url="tp-osg.ci.uchicago.edu"
> jobmanager="gt2:gt2:pbs" />
> <profile namespace="globus" key="queue">fast</profile>
> <workdirectory>/home/aespinosa/work</workdirectory>
> <profile namespace="karajan" key="initialScore">50</profile>
> <profile namespace="karajan" key="jobThrottle">10</profile>
> <profile namespace="globus" key="slots">20</profile>
> </pool>
> </config>
> gram log snippet:
> Mon Jun 8 16:19:21 2009 JM_SCRIPT: New Perl JobManager created.
> Mon Jun 8 16:19:21 2009 JM_SCRIPT: Using jm supplied job dir:
> /home/aespinosa/.globus/job/tp-grid1.ci.uchicago.edu/18222.1244495960
> Mon Jun 8 16:19:21 2009 JM_SCRIPT: Entering pbs submit
> Mon Jun 8 16:19:21 2009 JM_SCRIPT: NFS sync for /usr/bin/perl failed
> (may be harmless): Operation not permitted
> Mon Jun 8 16:19:21 2009 JM_SCRIPT: Sent NFS sync for /usr/bin/perl
> Mon Jun 8 16:19:21 2009 JM_SCRIPT: NFS sync for /dev/null failed (may
> Mon Jun 8 16:19:21 2009 JM_SCRIPT: Sent NFS sync for /dev/null
> Mon Jun 8 16:19:21 2009 JM_SCRIPT: Determining job max time cpu from
> job description
> Mon Jun 8 16:19:21 2009 JM_SCRIPT: using queue default
> Mon Jun 8 16:19:21 2009 JM_SCRIPT: Determining job max wall time
> limit from job description
> Mon Jun 8 16:19:21 2009 JM_SCRIPT: using maxwalltime of 60
> Mon Jun 8 16:19:21 2009 JM_SCRIPT: Building job script
> Mon Jun 8 16:19:21 2009 JM_SCRIPT: Transforming argument
> "/home/aespinosa/.globus/coasters/cscript6820117662705473060.pl"
> Mon Jun 8 16:19:21 2009 JM_SCRIPT: Transformed to
> "http://128.135.125.118:56015"
> Mon Jun 8 16:19:21 2009 JM_SCRIPT: Transforming argument "0608-190415-000000"
> Mon Jun 8 16:19:21 2009 JM_SCRIPT: Transformed to "0608-190415-000000"
> $grep fast gram*.log:
> gram_job_mgr_18021.log:6/8 16:19:15 JMI: poll_fast: returning -1 =
> GLOBUS_FAILURE (try Perl scripts)
> gram_job_mgr_18021.log:6/8 16:19:25 JMI: poll_fast: returning -1 =
> gram_job_mgr_18021.log:6/8 16:19:36 JMI: poll_fast: returning -1 =
> gram_job_mgr_18222.log:6/8 16:19:22 JMI: poll_fast: returning -1 =
> gram_job_mgr_18222.log:6/8 16:19:32 JMI: poll_fast: returning -1 =
> gram_job_mgr_18222.log:6/8 16:19:43 JMI: poll_fast: returning -1 =
> gram_job_mgr_18222.log:6/8 16:19:53 JMI: poll_fast: returning -1 =
> gram_job_mgr_18222.log:6/8 16:20:03 JMI: poll_fast: returning -1 =
> gram_job_mgr_18222.log:6/8 16:20:14 JMI: poll_fast: returning -1 =
> gram_job_mgr_18222.log:6/8 16:20:24 JMI: poll_fast: returning -1 =
> gram_job_mgr_18222.log:6/8 16:20:34 JMI: poll_fast: returning -1 =
> gram_job_mgr_18222.log:6/8 16:20:45 JMI: poll_fast: returning -1 =
> gram_job_mgr_18222.log:6/8 16:20:55 JMI: poll_fast: returning -1 =
> gram_job_mgr_18222.log:6/8 16:21:05 JMI: poll_fast: returning -1 =
> gram_job_mgr_18222.log:6/8 16:21:16 JMI: poll_fast: returning -1 =
> gram_job_mgr_18222.log:6/8 16:21:26 JMI: poll_fast: returning -1 =
> gram_job_mgr_18222.log:6/8 16:21:36 JMI: poll_fast: returning -1 =
> gram_job_mgr_18222.log:6/8 16:21:47 JMI: poll_fast: returning -1 =
> gram_job_mgr_18222.log:6/8 16:21:57 JMI: poll_fast: returning -1 =
> gram_job_mgr_18222.log:6/8 16:22:08 JMI: poll_fast: returning -1 =
> gram_job_mgr_18222.log:6/8 16:22:18 JMI: poll_fast: returning -1 =
> gram_job_mgr_18222.log:6/8 16:22:28 JMI: poll_fast: returning -1 =
> gram_job_mgr_18222.log:6/8 16:22:39 JMI: poll_fast: returning -1 =
> gram_job_mgr_18222.log:6/8 16:22:49 JMI: poll_fast: returning -1 =
> gram_job_mgr_18222.log:6/8 16:23:00 JMI: poll_fast: returning -1 =
> gram_job_mgr_18222.log:6/8 16:23:10 JMI: poll_fast: returning -1 =
> gram_job_mgr_18222.log:6/8 16:23:20 JMI: poll_fast: returning -1 =
> Swift version: Swift svn swift-r2949 cog-r2406
> -Allan
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
