[Swift-devel] Swift trunk seems to be broken
    Michael Wilde
    wilde at mcs.anl.gov
    Tue Jul 28 00:38:20 CDT 2009
That works - thanks!
Glen, please try your latest OOPS run again now.
- Mike
On 7/28/09 12:10 AM, Mihael Hategan wrote:
> Fixed in cog r2446.
> On Mon, 2009-07-27 at 23:51 -0500, Michael Wilde wrote:
>> I think its cog rev 2440 thats causing the problem.
>> 2440 fails:
>> com$ swift t3.swift
>> Swift svn swift-r3021 cog-r2440
>> RunID: 20090727-2333-dpf7v3ze
>> Execution failed:
>> 	org.globus.cog.karajan.workflow.KarajanRuntimeException: Could not
>> convert value to number: unbounded
>> Caused by:
>> 	For input string: "unbounded"
>> com$ cd -
>> /home/wilde/swift/src/cog/modules/swift
>> com$
>> com$
>> 2339 works:
>> com$ swift t3.swift
>> Swift svn swift-r3021 cog-r2439
>> RunID: 20090727-2337-g19sgr5f
>> com$
>> 2440 is:
>> com$ svn diff -r 2439:2440
>> Index:
>> modules/karajan/src/org/globus/cog/karajan/workflow/nodes/functions/Misc.java
>> (revision 2439)
>> (revision 2440)
>> @@ -84,7 +84,13 @@
>>   	public boolean sys_equals(VariableStack stack) throws
>> ExecutionException {
>>   		Object[] args = getArguments(ARGS_2VALUES, stack);
>> -		return args[0].equals(args[1]);
>> +		if (args[0] instanceof Number) {
>> +			Number n2 = TypeUtil.toNumber(args[1]);
>> +			return ((Number) args[0]).doubleValue() == n2.doubleValue();
>> +		else {
>> +			return args[0].equals(args[1]);
>> Exception in log (example) is below.
>> - Mike
>> 2009-07-27 21:36:28,559-0500 INFO  unknown Swift svn swift-r3019 (swift
>> modified locally) cog-r2445
>> 2009-07-27 21:36:28,561-0500 INFO  unknown RUNID
>> id=tag:benc at ci.uchicago.edu,2007:swift:run:20090727-2136-ibeu4gif
>> 2009-07-27 21:36:28,719-0500 DEBUG VDL2ExecutionContext
>> Caused by: org.globus.cog.karajan.workflow.KarajanRuntimeException:
>> Could not convert value to number: unbounded
>>          at org.globus.cog.karajan.util.TypeUtil.toNumber(TypeUtil.java:61)
>>          at
>> org.globus.cog.karajan.workflow.nodes.functions.Misc.sys_equals(Misc.java:88)
>>          at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>>          at
>> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:85)
>>          at
>> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:58)
>>          at
>> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:60)
>>          at java.lang.reflect.Method.invoke(Method.java:391)
>>          at
>> org.globus.cog.karajan.workflow.nodes.functions.FunctionsCollection.function(FunctionsCollection.java:78)
>>          at
>> org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.post(AbstractFunction.java:45)
>>          at
>> org.globus.cog.karajan.workflow.nodes.AbstractSequentialWithArguments.childCompleted(AbstractSequentialWithArguments.java(Compiled
>> Code))
>>          at
>> org.globus.cog.karajan.workflow.nodes.Sequential.notificationEvent(Sequential.java(Compiled
>> Code))
>>          at
>> org.globus.cog.karajan.workflow.nodes.FlowNode.event(FlowNode.java(Compiled
>> Code))
>>          at
>> org.globus.cog.karajan.workflow.events.EventBus.send(EventBus.java(Compiled
>> Code))
>>          at
>> org.globus.cog.karajan.workflow.events.EventBus.sendHooked(EventBus.java(Compiled
>> Code))
>>          at
>> org.globus.cog.karajan.workflow.nodes.FlowNode.fireNotificationEvent(FlowNode.java(Compiled
>> Code))
>>          at
>> org.globus.cog.karajan.workflow.nodes.FlowNode.complete(FlowNode.java(Compiled
>> Code))
>>          at
>> org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.executeChildren(AbstractFunction.java:37)
>>          at
>> org.globus.cog.karajan.workflow.nodes.FlowContainer.execute(FlowContainer.java(Compiled
>> Code))
>>          at
>> org.globus.cog.karajan.workflow.nodes.FlowNode.restart(FlowNode.java(Compiled
>> Code))
>>          at
>> org.globus.cog.karajan.workflow.nodes.FlowNode.start(FlowNode.java(Inlined
>> Compiled Code))
>>          at
>> org.globus.cog.karajan.workflow.nodes.FlowNode.controlEvent(FlowNode.java(Compiled
>> Code))
>>          at
>> Code))
>>          at
>> org.globus.cog.karajan.workflow.FlowElementWrapper.event(FlowElementWrapper.java(Compiled
>> Code))
>>          at
>> Code))
>>          at
>> org.globus.cog.karajan.workflow.events.EventBus.sendHooked(EventBus.java(Inlined
>> Compiled Code))
>>          at
>> org.globus.cog.karajan.workflow.events.EventWorker.run(EventWorker.java(Compiled
>> Code))
>> Caused by: java.lang.NumberFormatException: For input string: "unbounded"
>>          at
>> java.lang.NumberFormatException.forInputString(NumberFormatException.java(Compiled
>> Code))
>>          at
>> java.lang.FloatingDecimal.readJavaFormatString(FloatingDecimal.java(Compiled
>> Code))
>>          at java.lang.Double.valueOf(Double.java:227)
>>          at org.globus.cog.karajan.util.TypeUtil.toNumber(TypeUtil.java:51)
>>          ... 25 more
>> On 7/27/09 11:21 PM, Michael Wilde wrote:
>>> This script:
>>> com$ cat >t3.swift
>>> type d {
>>>   int x;
>>> com$
>>> Gives:
>>> com$ swift t3.swift
>>> Swift svn swift-r3019 cog-r2445
>>> RunID: 20090727-2313-2zka71if
>>> Execution failed:
>>> Caused by:
>>> com$
>>> com$ java -version
>>> java version "1.5.0_06"
>>> Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0_06-b05)
>>> Java HotSpot(TM) Server VM (build 1.5.0_06-b05, mixed mode)
>>> com$
>>> Is anyone else seeing this problem?
>>> This fails for me on both communicado and on the BG/P.
>>> On the BG/P I tried with both Java 2.4 and Java 6; both failed the same
>>> way.
>>> - Mike
>>> _______________________________________________
>>> Swift-devel mailing list
>>> Swift-devel at ci.uchicago.edu
>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
