[Swift-devel] Re: [Swift-user] XDTM
Michael Wilde
wilde at mcs.anl.gov
Sun Jul 26 18:09:59 CDT 2009
Jamal,
As Swift evolved from its early prototypes to a more mature system, the
notion of XDTM evolved to one of mapping between filesystem-based
structures and Swift in-memory data structures (ie, scalars, arrays, and
structures, which can be nested and typed).
This is best seen by looking at the "external" mapper, which allows a
user to map a dataset using any external program (typically a script)
that returns the members of the dataset as a two-column list: the Swift
variable reference, and the external file or URI.
See the user guide section on the external mapper:
http://www.ci.uchicago.edu/swift/guides/userguide.php#mapper.ext_mapper
(but the example in the user guide doesn't show the power of mapping to
nested structures).
In other words, it still has the flavor of XDTM, but without any XML
being visible to the user. It meets the same need but is easier to use
and explain.
- Mike
On 7/26/09 2:50 PM, J A wrote:
> Hi All:
> Can any one direct me to a source with more examples/explanation on
> how XDTM is working/implemented?
> Thanks,
> Jamal
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
