[Swift-devel] remote file mapping
    Mihael Hategan
    hategan at mcs.anl.gov
    Fri Jul 24 16:10:55 CDT 2009
On Fri, 2009-07-24 at 15:14 -0500, skenny at uchicago.edu wrote:
> thanks mihael!
> so, do you happen to know, would this mean that the gridftp
> server on the remote machine is configured to only accept
> requests from localhost?
Are you submitting from sidgrid.ci.uchicago.edu to
sidgrid.ci.uchicago.edu?
What does your script look like?
> RunID: 20090724-1504-5khkoyd7
> Progress:
> Execution failed:
>         java.lang.RuntimeException:
> java.lang.RuntimeException: Could not instantiate file resource
> Caused by:
>         Error communicating with the GridFTP server
> Caused by:
>         Authentication failed [Caused by: Operation
> unauthorized (Mechanism level: [JGLOBUS-56] Authorization
> failed. Expected "/CN=host/localhost.localdomain" target but
> received
> "/DC=edu/DC=uchicago/DC=ci/OU=hosts/CN=sidgrid.ci.uchicago.edu")]
> [skenny at sidgrid urltest]$
> ---- Original message ----
> >Date: Fri, 24 Jul 2009 13:47:58 -0500
> >From: Mihael Hategan <hategan at mcs.anl.gov>
> >Subject: Re: [Swift-devel] remote file mapping
> >To: skenny at uchicago.edu
> >Cc: swift-devel at ci.uchicago.edu
> >On Fri, 2009-07-24 at 13:25 -0500, skenny at uchicago.edu wrote:
> >> does anyone know the syntax for mapping a file on a remote
> >> machine? i'm told it's possible but couldn't find it in the
> doc.
> >You should be able to use a URL in any of the mappers. Like
> >"gsiftp://example.org/file".
