[Swift-devel] coaster workers not receiving enough jobs
Allan Espinosa aespinosa at cs.uchicago.edu
Thu Jul 23 12:08:17 CDT 2009
Ah right.
Reading more into logs and code, my guess is that there is not enough
Cpu.pull() calls to get jobs from the coaster service:
$ grep pull coasters.log | grep -v Later | cat -n
    62  2009-07-23 11:08:09,813-0500 INFO  Cpu 0723-021156-000001:51 pull
    63  2009-07-23 11:08:09,814-0500 INFO  Cpu 0723-021156-000001:52 pull
    64  2009-07-23 11:08:09,841-0500 INFO  Cpu 0723-021156-000001:53 pull
    65  2009-07-23 11:08:09,918-0500 INFO  Cpu 0723-021156-000001:54 pull
    66  2009-07-23 11:08:09,968-0500 INFO  Cpu 0723-021156-000001:55 pull
    67  2009-07-23 11:12:06,079-0500 INFO  Cpu 0723-021156-000001:56 pull
These pull() calls get invoked in the bunch of cpus in the pullthread
correct?  I'll read up on pullthreads and try to figure things out.
-Allan
2009/7/23 Mihael Hategan <hategan at mcs.anl.gov>:
> On Thu, 2009-07-23 at 11:40 -0500, Allan Espinosa wrote:
> There are ways to write it to avoid that warning, but that warning isn't
> indicative of an actual problem here.
