[Swift-devel] more on # of coasters workers vs actual requested on ranger
Allan Espinosa aespinosa at cs.uchicago.edu
Tue Jul 21 13:13:12 CDT 2009
aha.
on Ranger the count clause , refers to the number of cpus hence when
coasters is requesting for count=4 it only needs 1 node.  if we want
to do a workersPerNode=16 then we should manually specify host_count=4
instead of count=4.  or just use workersPerNode=1
i'll do more rsl exploration and probably play with the coaster's
generation of GRAM2 requests.
-Allan
2009/7/21 Mihael Hategan <hategan at mcs.anl.gov>:
> On Tue, 2009-07-21 at 11:49 -0500, Allan Espinosa wrote:
>> According to the gram logs, swift sends requests for blocks of 1, 2, 3
>> and 4 nodes but SGE receives requests for  four 1 node jobs.   This
>> maybe a GRAM2-SGE interaction problem.  Is there a way to get the
>> globus RSL files from swift so I can submit manually and verify this?
> In cog/modules/coaster/resources/log4.properties add:
> log4j.logger.org.globus.cog.abstraction.impl.execution.gt2.JobSubmissionTaskHandler=DEBUG
> Then re-compile.
> But I don't think you need to go that far. Write your own RSL. In
> particular I'd suggest trying with both jobType=multiple and without.
Allan M. Espinosa <http://allan.88-mph.net/blog>
PhD student, Computer Science
University of Chicago <http://people.cs.uchicago.edu/~aespinosa>
