[Swift-devel] [Bug 217] New: struct of structs via ext mapper
bugzilla-daemon at mcs.anl.gov
Wed Jul 15 11:45:33 CDT 2009
https://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=217
Summary: struct of structs via ext mapper
Product: Swift
Version: unspecified
Platform: PC
OS/Version: Linux
Status: NEW
Severity: normal
Priority: P2
Component: SwiftScript language
AssignedTo: benc at hawaga.org.uk
ReportedBy: aespinosa at cs.uchicago.edu
Swift is looking for a file describing the 2nd level struct itself.
my swift session
(latest on cog svn and swift svn) reports as follows:
RunID: testing
Progress:
Progress: Initializing site shared directory:1 Failed:1
Execution failed:
Mapper failed to map org.griphyn.vdl.mapping.DataNode
identifier
tag:benc at ci.uchicago.edu,2008:swift:dataset:20090714-1343-6lzjg014:720000000039
type AmplFilter with no value at dataset=res path=.out (not closed)
my instance_mapper.sh:
#!/bin/bash
while getopts ":i:" options; do
case $options in
i) export instance=$OPTARG ;;
*) exit 1;;
esac
done
echo "expend result/$instance/expend.dat";
echo "limits result/$instance/limits.dat";
echo "price result/$instance/price.dat";
echo "ratio result/$instance/ratio.dat";
echo "solve result/$instance/solve.dat";
echo "ofile result/$instance/stdout";
echo "out.expend_out result/$instance/expend.out";
echo "out.price_out result/$instance/price.out";
echo "out.ratio_out result/$instance/ratio.out";
here is the workflow i was working on:
type Template;
type AmplIn;
type StdOut;
type AmplCmd {
Template temp;
AmplIn mod;
AmplIn process;
AmplIn output;
AmplIn so;
AmplIn tree;
type ExpendDat;
type LimitsDat;
type PriceDat;
type RatioDat;
type SolveDat;
type ExpendOut;
type PriceOut;
type RatioOut;
type AmplFilter {
ExpendOut expend_out;
PriceOut price_out;
RatioOut ratio_out;
type AmplResult {
ExpendDat expend;
LimitsDat limits;
PriceDat price;
RatioDat ratio;
SolveDat solve;
StdOut ofile;
AmplFilter out;
app (AmplResult result) run_ampl (string instanceID, AmplCmd cmd)
run_ampl instanceID @filename(cmd.temp)
@filename(cmd.mod) @filename(cmd.process)
@filename(cmd.output) @filename(cmd.so) @filename(cmd.tree)
stdout=@filename(result.ofile);
AmplCmd const_cmd <ext;exec="./cmd_mapper.sh">;
int runs[]=[2001:2002];
foreach i in runs {
string instanceID = @strcat("run", i);
AmplResult res <ext;exec="./instance_mapper.sh", i=instanceID>;
res = run_ampl(instanceID, const_cmd);
Initial hack to get the script to work:
> Author: aespinosa
> Date: 2009-07-14 21:04:25 -0500 (Tue, 14 Jul 2009)
> New Revision: 3008
> Modified:
> SwiftApps/SEE/trunk/instance_mapper.sh
> Log:
> swift code now compiles with struct hack from ben
> Modified: SwiftApps/SEE/trunk/instance_mapper.sh
> --- SwiftApps/SEE/trunk/instance_mapper.sh 2009-07-14 22:06:08 UTC (rev 3007)
> +++ SwiftApps/SEE/trunk/instance_mapper.sh 2009-07-15 02:04:25 UTC (rev 3008)
> @@ -15,6 +15,7 @@
> +echo "out null";
Configure bugmail: https://bugzilla.mcs.anl.gov/swift/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are watching the assignee of the bug.
