[Swift-devel] Coasters and std's on ranger
    Michael Wilde
    wilde at mcs.anl.gov
    Tue Jul 14 08:30:22 CDT 2009
Sarah, if its still broken on Thu, I will look at it then.
I assume it happens on single job runs as well.
Can you create a simple 1-job test directory on Ranger that I can copy
to reproduce the problem?
Ben, if you can solve this, this week, that would be great.
Else Allan and I will look at it; guidance welcome.
Mike
On 7/14/09 2:05 AM, skenny at uchicago.edu wrote:
>> I see that in the current coaster code the stdout of the
> block task is
>> always redirected.
>> Try cog r2430 and keep the commented lines commented in the gt2
>> provider.
> 2009-07-14 01:14:30,525-0500 INFO  unknown Swift svn
> swift-r3005 cog-r2430 (cog modified locally)
> Execution failed:
>         Exception in RInvoke:
> Arguments: [scripts/4reg_dummy.R,
> matrices/4_reg/network1/gestspeech.cov, 2, 0.5, speech]
> Host: RANGER
> Directory:
> 4reg_speech-20090714-0114-ad0vxv90/jobs/z/RInvoke-zlbzzmdj
> stderr.txt:
> stdout.txt:
> Caused by:
>         Block task failed: 0714-140152-000000Block task ended
> prematurely
> Progress:  Submitted:18  Failed:16  Finished successfully:16
> Cleaning up...
> gram log:
> 7/14 01:25:44 JM: sending callback of status 4 (failure code
> 155) to https://128.135.125.211:50003/1247552072425.
> 7/14 01:25:44 JMI: testing job manager scripts for type fork
> exist and permissions are ok.
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
