[Swift-devel] Coaster CPU-time consumption issue
    Mihael Hategan
    hategan at mcs.anl.gov
    Mon Jul 13 13:23:15 CDT 2009
On Mon, 2009-07-13 at 12:28 -0500, Michael Wilde wrote:
> >> At the time we did not have a chance to gather detailed evidence, but I
> >> was surprised by two things:
> >> - that there were two Java processes and that one was so big. (Are most
> >> likely the active process was just a child thread of the main process?)
> > One java process is the bootstrap process (it downloads the coaster
> > jars, sets up the environment and runs the coaster service). It has
> > always been like this. Did you happen to capture the output of ps to a
> > file? That would be useful, because from what you are suggesting, it
> > appears that the bootstrap process is eating 100% CPU. That process
> > should only be sleeping after the service is started.
> I *thought* I captured the output of "top -u sarahs'id -b -d" but I cant
> locate it.
> As best as I can recall it showed the larger memory-footprint process to
> be relatively idle, and the smaller footprint process (about 275MB) to
> be burning 100% of a CPU.
Normally, the smaller footprint process should be the bootstrap. But
that's why I would like the ps output, because it sounds odd.
>   Allan will try to get a snapshot of this shortly.
> If this observation if correct, whats the best way to find out where its
> spinning? Profiling? Debug logging? Can you get profiling data from a
> JVM that doesnt exit?
Once I know where it is, I can look at the code and then we'll go from
there.
