[Swift-devel] imports
Ben Clifford
benc at hawaga.org.uk
Fri Jul 3 12:35:41 CDT 2009
swift r2996 contains an import directive which will import SwiftScript
code from other .swift files into the current program.
This is done deep in the compiler, and is not a preprocessor.
You can import the samefile multiple times without trouble it will only
be processed once.
At present you can only iport files that are in the current working
directory. $PTH/$CLASSPATH/$PERL5LIB style path handling should be
straightforward to implement, though.
