[Swift-devel] swift error ( gridftp problem)
yizhu
yizhu at cs.uchicago.edu
Wed Jul 1 04:33:58 CDT 2009
I have a problem when try running swift on Amazon EC2 with swift on
local computer.
The EC2 is configured as a globus Installed PBS cluster with one head
node and several and shared the /home/ directory via NFS , i've use
simpleCA to create a credential for both headnode (host certificate) and
user (user certificate).
after make simpleCA working, I finally get rid of "Authentication
Failure" when running swift, but a new problem occurs; it stuck on
"Progress: Initializing site shared directory:1" and finally failed
after several try. After that, I checked the "swift workdirectory" and
found that new directory has been created with a 0 byte file "_swiftwrap".
I also tried run globus-url-copy on client side, it failed with the file
named created at remote site but with 0 byte size. It seems that gridftp
can successfully create the directory and filename, but can not actually
transfer the data.
For the firewall setting on EC2, i opened tcp/udp 2119 (gridftp),
tcp/udp 2811(gram2), tcp/udp 8443 (gram4), (ssh), (https), (http).
-Yi
[1] Swift failed
-bash-3.2$ swift -tc.file ../tc.test.data -sites.file ../sites.test.xml
first.swift
Swift 0.9 swift-r2860 cog-r2388
RunID: 20090701-0344-zn2a66ub
Progress:
Progress: Failed:1
Execution failed:
Could not initialize shared directory on ec2_basecluster
Caused by:
Reply wait timeout. (error code 4)
-bash-3.2$
[2] Grid-ftp-failed
-bash-3.2$ globus-url-copy file:////home/yizhu/firstswift/hello.txt
gsiftp://ec2-174-129-90-225.compute-1.amazonaws.com/rec_data.txt
gsiftp://ec2-174-129-90-225.compute-1.amazonaws.com:2811/home/torqueuser/rec_data.txt
GlobusUrlCopy error: UrlCopy transfer failed. [Caused by: Server refused
performing the request. Custom message: (error code 1) [Nested
exception message: Custom message: Unexpected reply: 500-Command
failed. : globus_gridftp_server_file.c:globus_l_gfs_file_recv:1770:
500-globus_l_gfs_file_open failed.
500-globus_gridftp_server_file.c:globus_l_gfs_file_open:1694:
500-globus_xio_register_open failed.
500-globus_xio_file_driver.c:globus_l_xio_file_open:438:
500-Unable to open file /home/torqueuser/home/torqueuser/rec_data.txt
500-globus_xio_file_driver.c:globus_l_xio_file_open:381:
500-System error in open: No such file or directory
500-globus_xio: A system call failed: No such file or directory
500 End.]]
-bash-3.2$
-bash-3.2$
[3]-bash-3.2$ cat tc.test.data
ec2_basecluster echo /bin/echo INSTALLED
INTEL32::LINUX null
ec2_basecluster cat /bin/cat INSTALLED
INTEL32::LINUX null
ec2_basecluster ls /bin/ls INSTALLED
INTEL32::LINUX null
ec2_basecluster grep /bin/grep INSTALLED
INTEL32::LINUX null
ec2_basecluster sort /bin/sort INSTALLED
INTEL32::LINUX null
ec2_basecluster paste /bin/paste INSTALLED
INTEL32::LINUX null
ec2_basecluster wc /bin/wc INSTALLED
INTEL32::LINUX null
ec2_basecluster touch /bin/touch INSTALLED
INTEL32::LINUX null
ec2_basecluster sleep /bin/sleep INSTALLED
INTEL32::LINUX null
[4] -bash-3.2$ cat sites.test.xml
<config>
<pool handle="ec2_basecluster">
<gridftp url="gsiftp://ec2-174-129-90-225.compute-1.amazonaws.com" />
<jobmanager universe="vanilla"
url="ec2-174-129-90-225.compute-1.amazonaws.com/jobmanager-pbs" major="2" />
<workdirectory >/home/torqueuser</workdirectory>
</pool>
</config>
[5] debug version of swift run
first.swift -debug
Max heap: 268435456
kmlversion is >85d4b03e-7b73-49b7-81aa-096255181491<
build version is >85d4b03e-7b73-49b7-81aa-096255181491<
Recompilation suppressed.
Stack dump:
Level 1
[iA = 0, iB = 0, bA = false, bB = false]
vdl:instanceconfig = Swift configuration []
vdl:operation = run
vds.home = /home/yizhu/swift-0.9/bin/..
Using sites file: ../sites.test.xml
Using tc.data: ../tc.test.data
Setting resources to: {ec2_basecluster=ec2_basecluster}
RUNID id=tag:benc at ci.uchicago.edu,2007:swift:run:20090701-0348-vrb1yxl6
RunID: 20090701-0348-vrb1yxl6
closed org.griphyn.vdl.mapping.RootDataNode identifier
tag:benc at ci.uchicago.edu,2008:swift:dataset:20090701-0348-xecqa0zc:720000000001
type string value=Hello, world! dataset=unnamed SwiftScript value (closed)
ROOTPATH
dataset=tag:benc at ci.uchicago.edu,2008:swift:dataset:20090701-0348-xecqa0zc:720000000001
path=$
VALUE
VALUE=Hello, world!
NEW
id=tag:benc at ci.uchicago.edu,2008:swift:dataset:20090701-0348-xecqa0zc:720000000001
Found mapped data org.griphyn.vdl.mapping.RootDataNode identifier
tag:benc at ci.uchicago.edu,2008:swift:dataset:20090701-0348-xecqa0zc:720000000002
type messagefile with no value at dataset=outfile (not closed).$
NEW
id=tag:benc at ci.uchicago.edu,2008:swift:dataset:20090701-0348-xecqa0zc:720000000002
Progress:
PROCEDURE line=3 thread=0 name=greeting
PARAM thread=0 direction=output variable=t
provenanceid=tag:benc at ci.uchicago.edu,2008:swift:dataset:20090701-0348-xecqa0zc:720000000002
tag:benc at ci.uchicago.edu,2008:swift:dataset:20090701-0348-xecqa0zc:720000000003
type string value=hello.txt dataset=unnamed SwiftScript value (closed)
ROOTPATH
dataset=tag:benc at ci.uchicago.edu,2008:swift:dataset:20090701-0348-xecqa0zc:720000000003
path=$
VALUE
VALUE=hello.txt
START thread=0 tr=echo
Sorted: [ec2_basecluster:0.000(1.000):0/1 overload: 0]
Rand: 0.8176156212454151, sum: 1.0
Next contact: ec2_basecluster:0.000(1.000):0/1 overload: 0
START host=ec2_basecluster - Initializing shared directory
multiplyScore(ec2_basecluster:0.000(1.000):1/1 overload: 0, -0.01)
Old score: 0.000, new score: -0.010
No global submit throttle set. Using default (100)
Task(type=FILE_OPERATION, identity=urn:0-1-1246438105282) setting status
to Submitting
to Submitted
to Active
to Completed
multiplyScore(ec2_basecluster:-0.010(0.994):1/1 overload: 0, 0.01)
Old score: -0.010, new score: 0.000
multiplyScore(ec2_basecluster:0.000(1.000):1/1 overload: 0, 0.1)
Old score: 0.000, new score: 0.100
Task(type=FILE_OPERATION, identity=urn:0-1-1246438105282) Completed.
Waiting: 0, Running: 0. Heap size: 64M, Heap free: 30M, Max heap: 256M
multiplyScore(ec2_basecluster:0.100(1.060):1/1 overload: 0, -0.2)
Old score: 0.100, new score: -0.100
Task(type=FILE_TRANSFER, identity=urn:0-1-1246438105285) setting status
to Submitting
to Submitted
to Active
to Failed null
multiplyScore(ec2_basecluster:-0.100(0.943):1/1 overload: 0, -0.5)
Old score: -0.100, new score: -0.600
Releasing contact 2
commitDelayedScore(ec2_basecluster:-0.600(0.705):0/1 overload: 0, 0.1
Sorted: [ec2_basecluster:-0.500(0.747):0/1 overload: 0]
Rand: 0.4103224563240889, sum: 1.0
Next contact: ec2_basecluster:-0.500(0.747):0/1 overload: 0
multiplyScore(ec2_basecluster:-0.500(0.747):1/1 overload: -140, -0.01)
Old score: -0.500, new score: -0.510
Task(type=FILE_OPERATION, identity=urn:0-1-1246438105288) setting status
to Submitting
to Submitted
to Active
to Completed
multiplyScore(ec2_basecluster:-0.510(0.742):1/1 overload: 0, 0.01)
Old score: -0.510, new score: -0.500
multiplyScore(ec2_basecluster:-0.500(0.747):1/1 overload: 0, 0.1)
Old score: -0.500, new score: -0.400
Task(type=FILE_OPERATION, identity=urn:0-1-1246438105288) Completed.
Waiting: 0, Running: 0. Heap size: 64M, Heap free: 28M, Max heap: 256M
multiplyScore(ec2_basecluster:-0.400(0.791):1/1 overload: 0, -0.2)
Old score: -0.400, new score: -0.600
Task(type=FILE_TRANSFER, identity=urn:0-1-1246438105291) setting status
to Submitting
to Submitted
to Active
to Failed null
multiplyScore(ec2_basecluster:-0.600(0.705):1/1 overload: 0, -0.5)
Old score: -0.600, new score: -1.100
Releasing contact 3
commitDelayedScore(ec2_basecluster:-1.100(0.530):0/1 overload: 0, 0.1
Sorted: [ec2_basecluster:-1.000(0.561):0/1 overload: 0]
Rand: 0.653323366777857, sum: 1.0
Next contact: ec2_basecluster:-1.000(0.561):0/1 overload: 0
multiplyScore(ec2_basecluster:-1.000(0.561):1/1 overload: -199, -0.01)
Old score: -1.000, new score: -1.010
Task(type=FILE_OPERATION, identity=urn:0-1-1246438105294) setting status
to Submitting
to Submitted
to Active
to Completed
multiplyScore(ec2_basecluster:-1.010(0.557):1/1 overload: 0, 0.01)
Old score: -1.010, new score: -1.000
multiplyScore(ec2_basecluster:-1.000(0.561):1/1 overload: 0, 0.1)
Old score: -1.000, new score: -0.900
Task(type=FILE_OPERATION, identity=urn:0-1-1246438105294) Completed.
Waiting: 0, Running: 0. Heap size: 64M, Heap free: 27M, Max heap: 256M
multiplyScore(ec2_basecluster:-0.900(0.593):1/1 overload: 0, -0.2)
Old score: -0.900, new score: -1.100
Task(type=FILE_TRANSFER, identity=urn:0-1-1246438105297) setting status
to Submitting
to Submitted
to Active
to Failed null
multiplyScore(ec2_basecluster:-1.100(0.530):1/1 overload: 0, -0.5)
Old score: -1.100, new score: -1.600
Releasing contact 4
commitDelayedScore(ec2_basecluster:-1.600(0.403):0/1 overload: 0, 0.1
END_FAILURE thread=0 tr=echo
Progress: Failed:1
Caused by: null
Caused by:
org.globus.cog.abstraction.impl.file.IrrecoverableResourceException
Caused by: org.globus.ftp.exception.ServerException: Reply wait timeout.
(error code 4)
at
org.globus.cog.karajan.workflow.nodes.functions.KException.function(KException.java:29)
at
org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.post(AbstractFunction.java:45)
at
org.globus.cog.karajan.workflow.nodes.AbstractSequentialWithArguments.childCompleted(AbstractSequentialWithArguments.java:192)
at
org.globus.cog.karajan.workflow.nodes.Sequential.notificationEvent(Sequential.java:33)
at org.globus.cog.karajan.workflow.nodes.FlowNode.event(FlowNode.java:332)
at org.globus.cog.karajan.workflow.events.EventBus.send(EventBus.java:125)
at
org.globus.cog.karajan.workflow.events.EventBus.sendHooked(EventBus.java:99)
at
org.globus.cog.karajan.workflow.nodes.FlowNode.fireNotificationEvent(FlowNode.java:176)
at
org.globus.cog.karajan.workflow.nodes.FlowNode.complete(FlowNode.java:296)
at
org.globus.cog.karajan.workflow.nodes.FlowContainer.post(FlowContainer.java:58)
at
org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.post(AbstractFunction.java:46)
at
org.globus.cog.karajan.workflow.nodes.Sequential.startNext(Sequential.java:51)
at
org.globus.cog.karajan.workflow.nodes.Sequential.executeChildren(Sequential.java:27)
at
org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.executeChildren(AbstractFunction.java:40)
at
org.globus.cog.karajan.workflow.nodes.FlowContainer.execute(FlowContainer.java:63)
at
org.globus.cog.karajan.workflow.nodes.FlowNode.restart(FlowNode.java:233)
at org.globus.cog.karajan.workflow.nodes.FlowNode.start(FlowNode.java:278)
at
org.globus.cog.karajan.workflow.nodes.FlowNode.controlEvent(FlowNode.java:391)
at org.globus.cog.karajan.workflow.nodes.FlowNode.event(FlowNode.java:329)
at
org.globus.cog.karajan.workflow.FlowElementWrapper.event(FlowElementWrapper.java:227)
at
at
org.globus.cog.karajan.workflow.events.EventWorker.run(EventWorker.java:69)
Caused by: null
Caused by:
(error code 4)
at
org.globus.cog.karajan.workflow.events.FailureNotificationEvent.<init>(FailureNotificationEvent.java:36)
at
org.globus.cog.karajan.workflow.events.FailureNotificationEvent.<init>(FailureNotificationEvent.java:42)
at
org.globus.cog.karajan.workflow.nodes.FlowNode.failImmediately(FlowNode.java:151)
at
org.globus.cog.karajan.workflow.nodes.grid.AbstractGridNode.taskFailed(AbstractGridNode.java:314)
at
org.globus.cog.karajan.workflow.nodes.grid.AbstractGridNode.statusChanged(AbstractGridNode.java:276)
at
org.globus.cog.karajan.scheduler.AbstractScheduler.fireJobStatusChangeEvent(AbstractScheduler.java:168)
at
org.globus.cog.karajan.scheduler.LateBindingScheduler.statusChanged(LateBindingScheduler.java:656)
at
org.globus.cog.karajan.scheduler.WeightedHostScoreScheduler.statusChanged(WeightedHostScoreScheduler.java:421)
at
org.griphyn.vdl.karajan.VDSAdaptiveScheduler.statusChanged(VDSAdaptiveScheduler.java:410)
at
org.globus.cog.abstraction.impl.common.task.TaskImpl.notifyListeners(TaskImpl.java:236)
at
org.globus.cog.abstraction.impl.common.task.TaskImpl.setStatus(TaskImpl.java:224)
at
org.globus.cog.abstraction.impl.common.AbstractDelegatedTaskHandler.failTask(AbstractDelegatedTaskHandler.java:54)
at
org.globus.cog.abstraction.impl.fileTransfer.DelegatedFileTransferHandler.transferFailed(DelegatedFileTransferHandler.java:581)
at
org.globus.cog.abstraction.impl.fileTransfer.DelegatedFileTransferHandler.run(DelegatedFileTransferHandler.java:505)
at java.lang.Thread.run(Thread.java:595)
Caused by:
at
org.globus.cog.abstraction.impl.file.ftp.AbstractFTPFileResource.translateException(AbstractFTPFileResource.java:44)
at
org.globus.cog.abstraction.impl.file.ftp.AbstractFTPFileResource.translateException(AbstractFTPFileResource.java:33)
at
org.globus.cog.abstraction.impl.file.gridftp.old.FileResourceImpl.putFile(FileResourceImpl.java:430)
at
org.globus.cog.abstraction.impl.fileTransfer.DelegatedFileTransferHandler.doDestination(DelegatedFileTransferHandler.java:355)
at
org.globus.cog.abstraction.impl.fileTransfer.CachingDelegatedFileTransferHandler.doDestination(CachingDelegatedFileTransferHandler.java:47)
at
org.globus.cog.abstraction.impl.fileTransfer.DelegatedFileTransferHandler.run(DelegatedFileTransferHandler.java:492)
... 1 more
(error code 4)
at
org.globus.ftp.vanilla.FTPServerFacade$LocalControlChannel.waitFor(FTPServerFacade.java:511)
at org.globus.ftp.vanilla.TransferMonitor.run(TransferMonitor.java:129)
... 1 more
Execution failed:
Caused by:
Detailed exception:
Caused by: null
Caused by:
(error code 4)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Caused by: null
Caused by:
(error code 4)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Caused by:
at
at
at
at
at
at
... 1 more
(error code 4)
at
... 1 more
Swift finished with errors
-bash-3.2$
-bash-3.2$
