[Swift-devel] 'mapped type' terminology
Michael Wilde wilde at mcs.anl.gov
Wed Jan 28 08:56:55 CST 2009
I agree with this comment. Early on I felt that files should be a
primitive type - in the language today they show all the attributes of such.
One alternative is to add "file" to the list of atomic types.
Another is to call single files a mapped atomic type.
A third is to find a better name than "mapped type" or "marker".
Can a mapped atomic object be mapped to anything but a file?  Ie, if the
mapper associates a database or service handle with an object, encoded
as a string returned by the mapper, when the app is called, wont the
implementation attempt to locate and pass a file to the application?
(Sorry that this is digressing, but it seems that to name this concept
we need to make sure we understand its definition)
It seems that its the @filename() designation that causes the current
file-handling behavior at runtime, and other @something() primitives
could cause other runtime behavior (such as @handle() for passing the
opaque mapping or @database() for database-specific passing).
If we did this, then we are essentially expanding the possible set of
mapped atomic types. One way to do that is to define a tiny set of such
mapped atomic types. Two that would be useful are:
file == @filename()
data == @data() (for an opaque handle, or @handle)
- Mike
On 1/28/09 8:31 AM, Ben Clifford wrote:
>>From hpdc draft:
>> Types in Swift can be atomic or composite. An atomic type can be either
>> a primitive type or a mapped type.
> The phrasing of this kinda excludes the idea that composite types might be
> mapped, which is not true at all...
> The atomic types that are mapped to single files are what I initially
> called marker types; a better term was sought for that but 'mapped type'
> is not it in my opinion - being a mapped type or not is orthogonal to the
> atomic/composite distinction.
