[Swift-devel] a note on running coasters on osg's RENCI Engage	site
    Mihael Hategan
    hategan at mcs.anl.gov
    Mon Jan 26 12:39:51 CST 2009
On Mon, 2009-01-26 at 17:34 +0000, Ben Clifford wrote:
> On Mon, 26 Jan 2009, Mats Rynge wrote:
> > I'm surprised that the private address was not used already.
> It uses whatever the underlying stack tells it, which I think most likely
> is what the java.net.* library returns.
As far as I can remember from coding it, the coaster service explicitly
uses the GLOBUS_HOSTNAME that the service is started with for the
callback address.
> Even with a better API, its not clear to me what is the right way to
> determine which IP address goes where - a simple heuristic of 'RFC1918
> address = internal, non-RFC1918 address = external' will probably cover
> most cases, but not all.
We could test this, but I suspect that given one of the two strategies,
there will be some sites for which things won't work with it.
