[Swift-devel] swift changing walltime of prews-gram jobs
Ben Clifford benc at hawaga.org.uk
Sun Jan 25 07:54:43 CST 2009
Using coasters will cause job submissions with different walltimes than
your individual swift-level jobs.
Coaster workers get submitted with a longer walltime than the jobs you are
trying to send through. This is intended to result in coaster workers that
will run long enough to run many jobs.
At the moment, this is not very configurable. In the source code,
provider-coaster//src/org/globus/cog/abstraction/coaster/service/job/manager/WorkerManager.java
contains these fragments:
    public static final Seconds TIME_RESERVE = new Seconds(60);
    public static final int OVERALLOCATION_FACTOR = 10;
    startWorker(new Seconds(req.maxWallTime.getSeconds())
                            .multiply(OVERALLOCATION_FACTOR)
                            .add(TIME_RESERVE), req.prototype);
so whatever your maxwalltime is, you'll get coaster workers submitted with
ten times that plus one minute.
The coaster workers don't enforce job maxwalltimes, so you can work around
this by making the job maxwalltimes small enough so that 10*that+60s fits
inside the queue maximum wall time, even if that is actually too small for
your jobs.
You should see the same behaviour using local:pbs, which will use direct
PBS submission instead of GRAM; but you don't. That is an inconsistency
that suggests something is not right. My initial suspicion would be that
the cog PBS provider is not correctly passing either the walltime or queue
parameters. I will investigate this.
Probably coasters should get another configuration option to allow the
worker wall time to be more explicitly set, separately from job execution
wall times - that makes sense for sites where parameters such as queue
limits are well known by the user.
Thanks for testing 0.8rc1.
