[Swift-devel] swift jobs hanging on ranger
    skenny at uchicago.edu
    Wed Jan 21 13:37:39 CST 2009
>try swift without using coasters and see if that goes through;
still doesn't go thru and gives the same error in the gram
log. but it doesn't hang indefinitely on the submit host. it
gives:
Progress:  Stage in:1 Failed but can retry:2
Failed to transfer wrapper log from
env-20090121-1320-obxi57t5/info/4 on RANGER
env failed
Execution failed:
        Exception in env:
Arguments: []
Host: RANGER
Directory: env-20090121-1320-obxi57t5/jobs/4/env-4vv5nh5j
stderr.txt:
stdout.txt:
Caused by:
        The job manager detected an invalid script response
>cog-job-submit using coasters and see if that fails.
[skenny at gwynn check_env]$ cog-job-submit -p coaster -jm
gt2:gt2:SGE -a project=TG-DBS090006 -e /bin/hostname -s
gatekeeper.ranger.tacc.teragrid.org
Started local service: 128.135.92.83:50004
Socket bound. URL is http://gwynn.bsd.uchicago.edu:50005
[/129.114.50.163:34018] GET /coaster-bootstrap.jar HTTP/1.0
[/129.114.50.163:34023] GET /list?serviceId=1487248510 HTTP/1.1
GSSSChannel-null(0): Disabling heartbeats (config is null)
Initialized connection handler
Multiplexer 0 started
(1) Scheduling GSSSChannel-null(1) for addition
nullChannel started
Connection handler started
Multiplexer 1 started
GSSSChannel-null(1) REQ: Handler(CHANNELCONFIG)
Channel id: 341bc107:11efaac5124:-8000:-60989cff:11efaac517b:-8000
MetaChannel: 11644607 -> null: Disabling heartbeats (disabled
in config)
MetaChannel: 11644607 -> null.bind -> GSSSChannel-null(1)
GSSSChannel-null(1) REQ: Handler(REGISTER)
Trying to re-bind current channel
Sending Command(1, SUBMITJOB) on GSSSChannel-null(1)
Command(1, SUBMITJOB) CMD: Command(1, SUBMITJOB)
GSSSChannel-null(1) REPL: Command(1, SUBMITJOB)
Submitted task Task(type=JOB_SUBMISSION,
identity=urn:cog-1232566229197). Job id:
urn:1232566229197-1232566244068-1232566244069
Unregistering Command(1, SUBMITJOB)
GSSSChannel-null(1) REQ: Handler(JOBSTATUS)
Job completed
********logs for this are here:
/home/skenny/logs
