[Swift-devel] Re: Finding apps via $PATH
    Ben Clifford
    benc at hawaga.org.uk
    Wed Jan 14 02:14:50 CST 2009
On Tue, 13 Jan 2009, Mats Rynge wrote:
> > Omit the path in a tc.data entry (eg say echo instead of /bin/echo) and
> > $PATH will be used to look up the executable. This is in SVN head and also
> > in the 0.7 release.
> Note that on OSG you will find that most sites have no or a very minimal
> $PATH.
RIght. In that case, its probably most useful in conjunction with
PATHPREFIX so that you can define your application bin directory once per
site, rather than once per executable per site.
I think it should also work nicely with the SoftEnv RSL options available
on teragrid (though I haven't tried).
