[Swift-devel] Problem using @extractint() on derived file
Ben Clifford benc at hawaga.org.uk
Wed Feb 25 03:45:32 CST 2009
On Tue, 24 Feb 2009, Michael Wilde wrote:
> substituting readData for @extractint in the above works as well.
ok good.
rambling slightly:
It would be nice to get rid of @extractint and have only readData, but I
think that this doesn't work in all cases: readData's behaviour is
controlled by the type that it is expected to return (that is, if you
assign a readData expression to an int, it tries to read an int; if you
assign it to an array, it tries to read an array). In some situations,
that return type isn't well defined, because it could be a context where
anything is accepted - for example what is the type of
readData in: trace(readData(f))
