[Swift-devel] Iterate example broken - semantics changed?
    Michael Wilde
    wilde at mcs.anl.gov
    Tue Feb 24 16:21:47 CST 2009
The iterate example in the swift tutorial no longer works.
Its at:
http://www.ci.uchicago.edu/swift/guides/tutorial.php#tutorial.iterate
The problem seems to be the same as the example below: swift wont let
you set the members of an array both in the declaring scope and in an
inner nested scope, it seems.
This example:
int a[];
a[0] = 0;
iterate v {
   a[v+1] = v+1;
   trace("v=",v);
} until ();
gives:
Could not start execution.
         variable a has multiple writers.
