[Swift-devel] Contribution: swift-osg-ress-site-catalog
Mats Rynge
rynge at renci.org
Mon Feb 16 17:01:50 CST 2009
Attached is a contribution for Swift. It is a script which queries the
OSG Resource Selection System (ReSS) for site information and builds a
Swift site catalog. I think the script should be located in bin/, but
feel free to include it anywhere in the distribution.
I have already submitted a signed contribution license agreement, and
this script is contributed under that agreement.
Mats Rynge
Renaissance Computing Institute <http://www.renci.org>
#!/usr/bin/perl
use strict;
use Pod::Usage;
use Getopt::Long;
use File::Temp qw/ tempfile tempdir mktemp /;
my $opt_help = 0;
my $opt_vo = 'engage';
my $opt_engage_verified = 0;
my $opt_gt4 = 0;
my $opt_out = '&STDOUT';
Getopt::Long::Configure('bundling');
GetOptions(
"help" => \$opt_help,
"vo=s" => \$opt_vo,
"engage-verified" => \$opt_engage_verified,
"gt4" => \$opt_gt4,
"out=s" => \$opt_out,
) or pod2usage(1);
if ($opt_help) {
pod2usage(1);
if ($opt_engage_verified && $opt_vo ne "engage") {
die("You can not specify a vo when using --engage-verified\n");
# make sure condor_status is in the path
my $out = `which condor_status 2>/dev/null`;
if ($out eq "") {
die("This tool depends on condor_status.\n" .
"Please make sure condor_status in your path.\n");
my %ads;
my %tmp;
my $cmd = "condor_status -any -long -constraint" .
" 'StringlistIMember(\"VO:$opt_vo\";GlueCEAccessControlBaseRule)'" .
" -pool osg-ress-1.fnal.gov";
# if we want the engage verified sites, ignore opt_vo and query against
# engage central collector
if ($opt_engage_verified) {
" 'SiteVerified==TRUE'" .
" -pool engage-central.renci.org"
open(STATUS, "$cmd|");
while(<STATUS>) {
chomp;
if ($_ eq "") {
if ($tmp{'GlueSiteName'} ne "") {
my %copy = %tmp;
$ads{$tmp{'GlueSiteName'}} = \%copy;
undef %tmp;
else {
my ($key, $value) = split(/ = /, $_, 2);
$value =~ s/^"|"$//g; # remove quotes from Condor strings
$tmp{$key} = $value;
close(STATUS);
# lowercase vo
my $lc_vo = lc($opt_vo);
open(FH, ">$opt_out") or die("Unable to open $opt_out");
print FH "<config>\n";
foreach my $sitename (keys %ads) {
my $contact = $ads{$sitename}->{'GlueCEInfoContactString'};
my $host = $contact;
$host =~ s/:.*//;
my $jm = $contact;
$jm =~ s/.*jobmanager-//;
if ($jm eq "pbs") {
$jm = "PBS";
elsif ($jm eq "lsf") {
$jm = "LSF";
elsif ($jm eq "sge") {
$jm = "SGE";
elsif ($jm eq "condor") {
$jm = "Condor";
my $workdir = $ads{$sitename}->{'GlueCEInfoDataDir'};
print FH "\n";
print FH " <!-- $sitename -->\n";
print FH " <pool handle=\"$sitename\" >\n";
print FH " <gridftp url=\"gsiftp://$host/\" />\n";
if ($opt_gt4) {
print FH " <execution provider=\"gt4\" jobmanager=\"$jm\" url=\"$host:9443\" />\n";
else {
print FH " <jobmanager universe=\"vanilla\" url=\"$contact\" major=\"2\" />\n";
print FH " <workdirectory >$workdir/$lc_vo/tmp</workdirectory>\n";
print FH " </pool>\n";
print FH "\n</config>\n";
close(FH);
exit(0);
__END__
=head1 NAME
swift-osg-ress-site-catalog - converts ReSS data to Swift site catalog
=head1 SYNOPSIS
swift-osg-ress-site-catalog [options]
=head1 OPTIONS
=over 8
=item B<--help>
Show this help message
=item B<--vo=[name]>
Set what VO to query ReSS for
=item B<--engage-verified>
Only retrieve sites verified by the Engagement VO site verification tests
This can not be used together with --vo, as the query will only work for
sites advertising support for the Engagement VO.
This option means information will be retrieved from the Engagement collector
instead of the top-level ReSS collector.
=item B<--out=[filename]>
Write to [filename] instead of stdout
=back
=head1 DESCRIPTION
B<swift-osg-ress-site-catalog> converts ReSS data to Swift site catalog
=cut
