[Swift-devel] Status of coasters
    Tim Freeman
    tfreeman at mcs.anl.gov
    Fri Feb 13 09:40:32 CST 2009
On Fri, 13 Feb 2009 09:32:43 -0600
Mihael Hategan <hategan at mcs.anl.gov> wrote:
> On Fri, 2009-02-13 at 09:23 -0600, Michael Wilde wrote:
> > On 2/13/09 9:17 AM, Mihael Hategan wrote:
> > > On Fri, 2009-02-13 at 08:59 -0600, Michael Wilde wrote:
> > >> -- Service submits via WS-GRAM. This should be tested, on sites where
> > >> WS-GRAM is working.
> > >> This woild use jobmanager=gt2:gt4:{pbs/condor/sge}, and needs to be
> > >> tested. For sites where WS-GRAM is not functional, I suggested we
> > >> consider configuring our own non-root WS-GRAM, ideally using
> > >> already-installed GT4 software, eg, from the OSG package on OSG and TG
> > >> sites where its installed. Mihael thought this would be considerable
> > >> work.
> > > Not as much the amount of work, but:
> > > 1. getting root on sites (if installed for multiple users)
> > I was thinking/hoping we could have a single setup script, which we'd
> > pre-install where required, that would configure and start a personal
> > WSRF container for the user. Which would be work for us to create,
> > install and maintain, but, if successful, would be transparent to the user.
> You need root to configure sudo.
Why would you need sudo for gram if it mapped to the same account?
> I also don't think you can easily automate the gt4 installation process.
> There's manual configuration that needs to be done. I suggest installing
> your own gt4 once to which I can submit jobs to get an idea of what's
> involved.
For non-gram, there's an auto script here:
    http://workspace.globus.org/vm/TP2.2/admin/quickstart.html#auto-container
The questions it asks users (is this the right hostname? etc) could also be
scripted.
Getting from there to GRAM4 auto-configuration should not be too much of a step
(the nimbus contextualization scripts have done it for gram4).
Tim
