[Swift-devel] Rename versions of Globus commands in swift/bin?
Michael Wilde wilde at mcs.anl.gov
Wed Feb 11 23:46:20 CST 2009
On 2/11/09 11:33 PM, Mihael Hategan wrote:
> On Wed, 2009-02-11 at 22:37 -0600, Michael Wilde wrote:
>> These are cog-based versions of the commands.
>> The cool thing is that users get this core Globus functionality with no
>> compilation needed: just untar Swift, and poof, you can make proxies,
>> run jobs, move files (eg for setting this up on remote grid sites).
> We rename them to cog-* then?
That would be fine by me. Unless Ben weighs in with a different view,
please do.
>> The issue I bumped into with proxies was cosmetic. The proxies are
>> totally compatible as far as I know.
> Yes.
>>   I just happened to have a
>> front-end script for running swift code that checked to make sure the
>> user has a valid proxy with some time left. And the time format returned
>> by the swift grid-proxy-info was slightly different than the Globus one.
>> That broke my brittle little script - its not a criticism of the cog
>> code version.
> Though that may be possible to fix. url-copy not so much.
I think this is pretty low on the prio list. If its easy, yes, please
do. Else file it as low prio in bugzilla, imo.
>> But its easy enough for us to refer, in swift docs, to swift-proxy-init,
>> swift-proxy-info with a * explaining that the Globus versions of these
>> are fine if you happen to have them.
> Or the other way around. We use globus-* by default and then say that
> the user could use the other ones.
Yes, that would be better. OSG and TG users are likely to have the
globus- versions in their paths. New users running swift on their own
hosts are likely not to.
At the moment, the users guide doesnt cover this at all; its a future
issue for when it does.
- Mike
>> - Mike
>> On 2/11/09 10:31 PM, Ian Foster wrote:
>>> Mike:
>>> This begs the question for me as to why they are different. Are Swift
>>> proxies different from Globus proxies, for example? And if so, why?
>>> Ian.
>>> On Feb 11, 2009, at 10:29 PM, Michael Wilde wrote:
>>>> Matt raises a good point below. Can we rename globus-url-copy,
>>>> grid-proxy-init, and other commands that have the same name as Globus
>>>> commands, to swift-url-copy, swift-proxy-init, etc?
>>>> Especially for those that are not identical enough to the Globus
>>>> versions (where that is tbd).
>>>> Its extremely handy to have these commands there, but perhaps
>>>> confusing for some users that get these in their paths ahead of the
>>>> Globus versions. I realize calling them swift-* causes its own kind of
>>>> confusion, but I'm excited that folks like Mats are installing Swift
>>>> for users, and I'd like to remove any barriers, even the small ones.
>>>> This is likely to be a bigger issue for users with the OSG client
>>>> stack installed.
>>>> On 2/11/09 10:18 PM, Michael Wilde wrote:
>>>>> On 2/11/09 9:28 PM, Mats Rynge wrote:
>>>>>> Regarding bin/, it is pretty evil to have a globus-url-copy under the
>>>>>> swift bin/ which has a different set of command line options as the
>>>>>> Globus one. I had a plan on adding swift to the default path on our
>>>>>> submit node so all our users could use swift without doing anything
>>>>>> special. But having a different globus-url-copy means it would break
>>>>>> things for other users.
>>>>> I know what you mean. I actually got bit the other day by our copy of
>>>>> grid-proxy-init - I was seeing the globus one, and one of my users
>>>>> was seeing the swift one, with a slightly different output that broke
>>>>> a script.
>>>>> So I agree - if the swift version is not pretty near identical, its
>>>>> better to give it another name. I'll past your comment to the devel
>>>>> list with a suggestion that we rename it. Perhaps swift-proxy-init,
>>>>> swift-url-copy? (not sure how that will go over... ;)
>>>>> - Mike
>>>> Mats, I would just go ahead and remove or rename those, in the meantime.
>>>> I dont think anything points to them.
>>>> - Mike
>>>> _______________________________________________
>>>> Swift-devel mailing list
>>>> Swift-devel at ci.uchicago.edu
>>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
