[Swift-devel] Rename versions of Globus commands in swift/bin?
Michael Wilde wilde at mcs.anl.gov
Wed Feb 11 22:37:35 CST 2009
These are cog-based versions of the commands.
The cool thing is that users get this core Globus functionality with no
compilation needed: just untar Swift, and poof, you can make proxies,
run jobs, move files (eg for setting this up on remote grid sites).
The issue I bumped into with proxies was cosmetic. The proxies are
totally compatible as far as I know.  I just happened to have a
front-end script for running swift code that checked to make sure the
user has a valid proxy with some time left. And the time format returned
by the swift grid-proxy-info was slightly different than the Globus one.
That broke my brittle little script - its not a criticism of the cog
code version.
But its easy enough for us to refer, in swift docs, to swift-proxy-init,
swift-proxy-info with a * explaining that the Globus versions of these
are fine if you happen to have them.
- Mike
On 2/11/09 10:31 PM, Ian Foster wrote:
> Mike:
> This begs the question for me as to why they are different. Are Swift
> proxies different from Globus proxies, for example? And if so, why?
> Ian.
> On Feb 11, 2009, at 10:29 PM, Michael Wilde wrote:
>> Matt raises a good point below. Can we rename globus-url-copy,
>> grid-proxy-init, and other commands that have the same name as Globus
>> commands, to swift-url-copy, swift-proxy-init, etc?
>> Especially for those that are not identical enough to the Globus
>> versions (where that is tbd).
>> Its extremely handy to have these commands there, but perhaps
>> confusing for some users that get these in their paths ahead of the
>> Globus versions. I realize calling them swift-* causes its own kind of
>> confusion, but I'm excited that folks like Mats are installing Swift
>> for users, and I'd like to remove any barriers, even the small ones.
>> This is likely to be a bigger issue for users with the OSG client
>> stack installed.
>> On 2/11/09 10:18 PM, Michael Wilde wrote:
>>> On 2/11/09 9:28 PM, Mats Rynge wrote:
>>>> Regarding bin/, it is pretty evil to have a globus-url-copy under the
>>>> swift bin/ which has a different set of command line options as the
>>>> Globus one. I had a plan on adding swift to the default path on our
>>>> submit node so all our users could use swift without doing anything
>>>> special. But having a different globus-url-copy means it would break
>>>> things for other users.
>>> I know what you mean. I actually got bit the other day by our copy of
>>> grid-proxy-init - I was seeing the globus one, and one of my users
>>> was seeing the swift one, with a slightly different output that broke
>>> a script.
>>> So I agree - if the swift version is not pretty near identical, its
>>> better to give it another name. I'll past your comment to the devel
>>> list with a suggestion that we rename it. Perhaps swift-proxy-init,
>>> swift-url-copy? (not sure how that will go over... ;)
>>> - Mike
>> Mats, I would just go ahead and remove or rename those, in the meantime.
>> I dont think anything points to them.
>> - Mike
>> Swift-devel mailing list
>> Swift-devel at ci.uchicago.edu
>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
