[Swift-devel] Rename versions of Globus commands in swift/bin?
Michael Wilde wilde at mcs.anl.gov
Wed Feb 11 22:29:17 CST 2009
Matt raises a good point below. Can we rename globus-url-copy,
grid-proxy-init, and other commands that have the same name as Globus
commands, to swift-url-copy, swift-proxy-init, etc?
Especially for those that are not identical enough to the Globus
versions (where that is tbd).
Its extremely handy to have these commands there, but perhaps confusing
for some users that get these in their paths ahead of the Globus
versions. I realize calling them swift-* causes its own kind of
confusion, but I'm excited that folks like Mats are installing Swift for
users, and I'd like to remove any barriers, even the small ones.
This is likely to be a bigger issue for users with the OSG client stack
installed.
On 2/11/09 10:18 PM, Michael Wilde wrote:
> On 2/11/09 9:28 PM, Mats Rynge wrote:
>> Regarding bin/, it is pretty evil to have a globus-url-copy under the
>> swift bin/ which has a different set of command line options as the
>> Globus one. I had a plan on adding swift to the default path on our
>> submit node so all our users could use swift without doing anything
>> special. But having a different globus-url-copy means it would break
>> things for other users.
> I know what you mean. I actually got bit the other day by our copy of
> grid-proxy-init - I was seeing the globus one, and one of my users was
> seeing the swift one, with a slightly different output that broke a script.
> So I agree - if the swift version is not pretty near identical, its
> better to give it another name. I'll past your comment to the devel list
> with a suggestion that we rename it. Perhaps swift-proxy-init,
> swift-url-copy? (not sure how that will go over... ;)
> - Mike
Mats, I would just go ahead and remove or rename those, in the meantime.
I dont think anything points to them.
- Mike
