[Swift-devel] scheduler stuff for Google Summer of Code 2009
    Ian Foster
    foster at anl.gov
    Wed Feb 11 15:35:56 CST 2009
I would argue that Swift support for collective operations also helps
with scaling. (We can run a computation with 1M tasks, if not all 1M
tasks are active at once.)
On Feb 11, 2009, at 3:33 PM, Mihael Hategan wrote:
> ----- Ben Clifford <benc at hawaga.org.uk> wrote:
>> On Wed, 11 Feb 2009, Michael Wilde wrote:
>>> - scaling swift to 1M+ task workflows, efficiently (streaming the
>>> mappers)
>> There's more to this than simple streaming mappers.
>> At the moment, everything is built around having a Java object in
>> memory
>> for every piece of data that can be referenced, and that object
>> tends to
>> stick around for a long time (at least as long as that data can be
>> referenced). For example, if you have an array which has a large
>> number of
>> elements, then each of those elements has at least one object in
>> memory
>> representing it, because as long as you have the array in scope,
>> you can
>> say a[1] or a[anything] and thus get to every element.
> I do not think that this issue is the bottleneck here. For every
> application
> invocation there is a karajan thread. The fact that one such thread
> eats
> around 10-20k seems to be the problem. By contrast, a piece of Swift
> data
> probably takes less than 1k.
> So I think that one order of magnitude improvement could be achieved
> by
> addressing that 10-20k problem (or by somehow having fewer karajan
> threads).
>> The in-memory implementation of the data model and anything that
>> touches
>> it would need some fairly serious work to cope with having stuff
>> kept out
>> of core; and I think keeping stuff out of core is something that
>> would
>> need to happen.
>> (that is, 'streaming mappers' as a phrase seems to deal with "not
>> getting
>> knowledge about data too fast" but does not deal with "forgetting
>> knowledge about data fast enough")
>> Swift-devel mailing list
>> Swift-devel at ci.uchicago.edu
>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
