[Swift-devel] Problems with coasters and managedfork jobmanager
Ben Clifford
benc at hawaga.org.uk
Wed Feb 11 09:00:29 CST 2009
On Wed, 11 Feb 2009, Ian Foster wrote:
> The meaning of the answer "yes" to a negative question has different meanings
> depending on one's cultural origins :)
ha. indeed.
> What did you mean in this case?
job flow is cog commandline -> cog gt2 provider -> gram2 -> condor -> go!
This problem occurs with any use of Condor up until fairly recent
versions. The Condor job submission file format (which in this case is
being generated by gram2, but that is mostly irrelevant) doesn't cope with
spaces in arguments:
Normally:
echo "hi there"
has $1 equal to the entire string: hi there
and no $2
If you submit the same through condor, you get $1=hi and $2=there
This then causes problems using on-the-commandline command sequences in sh
or perl:
Something like this:
sh -c 'echo foo'
which passes the entire command "echo foo" as the second parameter to sh
gets turned into something like:
$1=-c (which is ok)
$2=echo (or maybe 'echo)
$3=foo (or maybe foo')
so sh runs the command "echo" with no parameters (as $2 instructs it to).
So its hard to run any non-trivial command through this mechanism.
There's future hope, though, as a hopefully fixed GRAM update is
available, working with a recently fixed Condor, and that is likely to be
deployed on OSG in due course (which is where most Condor woes occur).
