[Swift-devel] typecheck foo[*].bar
Ben Clifford benc at hawaga.org.uk
Tue Feb 10 07:12:40 CST 2009
I noticed today that expressions like this don't get typechecked properly,
so in 0.8, you can't use [*].member expressions. Bleugh.
As I want to use such expressions (or equivalent), I guess I have to fix
that soonish.
I think the approach I am favouring language-wise is that [*] becomes a
no-op/identity operator, and . with an array of structs on the left
returns an array of the appropriate member fields.
Thus   a[*] == a   for all arrays a
       a[*].foo == a.foo == (in haskelly pseudocode) (map \(x->x.foo) a)
I think from an implementation point of view, that can cause some trouble
though. DSHandles expect to have only one parent. Writing an expression
a[*].foo causes each element to then have two potential parents:
     i.        array of structs  -> contained structure -> foo
     ii.       array of foos -> foo
Although something like this must be happening at the moment anyway with
the [*].foo syntax, so it might not turn out to be a big deal.
