[Swift-devel] Problems with coasters and managedfork jobmanager
Michael Wilde
wilde at mcs.anl.gov
Mon Feb 9 18:23:39 CST 2009
It sounds reasonable, but lets try it and see how well it works.
I'd like to create a test that runs a trivial swift script on a set of
osg and tg sites with coasters.
If you create a patch or check it in I'll try it too.
- Mike
On 2/9/09 6:16 PM, Mihael Hategan wrote:
> I did get a one-liner perl which contains an encoded bootstrap jar file
> (only printable characters). Perl cares less about whitespace, which
> makes me think it's a better candidate if we want to go that way.
> Thoughts?
> On Mon, 2009-02-09 at 17:05 -0600, Michael Wilde wrote:
>> No, correction, I mis-spoke. When I try this direct to the shell (as
>> opposed to via swift and coaster bootstrap) I get the same error as you
>> show. I cant get sh to accept function defs on 1 line.
>> So I must have mis-interpreted my result from last Friday.
>> - Mike
>> On 2/9/09 4:06 PM, Michael Wilde wrote:
>>> sorry, i think i put the wrong version there; i dealt with that specific
>>> problem and hit a subtler one, deeper in the bootstrap process.
>>> On 2/9/09 2:34 PM, Mihael Hategan wrote:
>>>> I asked because I couldn't figure out how to get it to work.
>>>> But it seems like yours has problems, too:
>>>> mike at blabla tmp$ sh bootstrap.nonl.sh
>>>> bootstrap.nonl.sh: line 1: syntax error near unexpected token `;'
>>>> On Mon, 2009-02-09 at 14:23 -0600, Michael Wilde wrote:
>>>>> its www.ci.uchicago.edu/~wilde/bootstrap.nonl.sh, plus I removed the
>>>>> code in ServiceManager that inserted the extra newlines when reading
>>>>> it into a string buffer. I checked as far as verifying in the gram
>>>>> log that it was seen by gram as a single line in the rsl. I never
>>>>> got a successful run from it, though - it ran into other problems later.
>>>>> On 2/9/09 1:46 PM, Mihael Hategan wrote:
>>>>>> On Fri, 2009-02-06 at 10:33 -0600, Michael Wilde wrote:
>>>>>>> I dont know, but I am testing a version where I removed the
>>>>>>> newlines from bootstrap.pl (and adjusted a few bits manually)
>>>>>> May we see that?
>>>>>>> and I *think* its moving on to the next stage and trying to start
>>>>>>> the workers.
>>>>>>> Ben, it seems that *some* whitespace is passed on OK, in that I can
>>>>>>> run a job that does echo "hello world" and that blank after hello
>>>>>>> is preserved, and the job runs. I assume the whitespace problem is
>>>>>>> more subtle than that?
>>>>>>> On 2/6/09 10:24 AM, Mihael Hategan wrote:
>>>>>>>> On Fri, 2009-02-06 at 16:17 +0000, Ben Clifford wrote:
>>>>>>>>> On Fri, 6 Feb 2009, Mihael Hategan wrote:
>>>>>>>>>> I guess we'll have to stage in the bootstrap script using the
>>>>>>>>>> stage-in
>>>>>>>>>> directive if we are to support managed fork, since I don't see OSG
>>>>>>>>>> fixing the issue.
>>>>>>>>> They are fixing the whitespace in parameters - see the gram-user
>>>>>>>>> thread I sent in a different message.
>>>>>>>> Does this include the new lines?
>>> _______________________________________________
>>> Swift-devel mailing list
>>> Swift-devel at ci.uchicago.edu
>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
