[Swift-devel] bash profile emitting text causes md5sum to be not located
Ben Clifford
benc at hawaga.org.uk
Mon Feb 9 05:12:22 CST 2009
On teraport, my .bash_profile emits some information to stdout at login.
That causes bootstrap.sh to be unable to get confused (it takes the
bash_profile output to be the name of the md5sum executable, and then is
unable to execute).
This change stops that happening for me:
-MD5SUM=`find 'which gmd5sum'`
+MD5SUM=`which gmd5sum`
if [ "X$MD5SUM" == "X" ]; then
- MD5SUM=`find 'which md5sum'`
+ MD5SUM=`which md5sum`
This is because the find command (which is a shell procedure in this case,
not unix find) first invokes the command, and if it gives no output,
invokes it again with a bash login shell, which then does give output in
the gmd5sum case when it should not.
I think maybe that this should not happen in the bowels of the bootstrap
script - either the environment is correctly initialised for the whole
bootstrap script, or it is not. (this ties into the question of whether
bash should be invoked with -l or not for the whole bootstrap script and
other environmental configuration)
