[Swift-devel] strange behavior evaluating function call as trace arg
Ben Clifford
benc at hawaga.org.uk
Thu Feb 5 09:31:09 CST 2009
On Wed, 4 Feb 2009, Michael Wilde wrote:
> trace(add(123,456));
> Could not compile SwiftScript source: line 13:1: unexpected token: trace
related to this, there's a bug open related to syntax error - bug 173:
http://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=173
The syntax error should be reporting that add is not valid there, not that
trace is an unexpected token.
This comes, I think, from deciding whether a statement is a procedure
declaration or a procedure call by attempting to parse the entire first
bit up to this:
foo (syntactically valid argument declarations) {
or
foo (syntactically valid argument expressions) ;
to distinguish between declarations or invocations.
In the case above, your statement matches neither of the above and so it
tries to parse neither as a declaration or an invocation, giving an overly
general error message saying, essentially, "i don't know what this whole
statement is".
It may be possible to make better predictors or otherwise tighten up the
location, but I had trouble last time. Having had a year to think about
it, I may be able to come up with something better.
