[Swift-devel] coasters paths (was Re: Coasters failing on Teraport - cant find Java?)
Allan Espinosa
aespinosa at cs.uchicago.edu
Tue Feb 3 17:02:22 CST 2009
I also am having path problems in running coasters remotely. This
time its looking for "curl" and "wget" (all are in /usr/bin)
logfile snippet:
Caused by: org.globus.cog.abstraction.impl.common.task.TaskSubmissionException:
Could not submit job
Could not start coaster service
Task ended before registration was received.
STDOUT: No wget or curl available
using globus-job-run, it also does not find these binaries by default.
using an "sh -l" gives me tty permission errors in ranger
[aespinosa at communicado ~]$ globus-job-run
gatekeeper.ranger.tacc.teragrid.org /usr/bin/which wget
/usr/bin/which: no wget in ((null))
gatekeeper.ranger.tacc.teragrid.org /bin/sh -l -c "which curl"
stty: standard input: Inappropriate ioctl for device
On Tue, Jan 27, 2009 at 1:41 PM, Michael Wilde <wilde at mcs.anl.gov> wrote:
> Related to: Re: [Swift-devel] swift changing walltime of prews-gram jobs
> I can't get a Swift script to run on coasters on TeraPort in gt2:gt2:pbs
> mode.
> Im using 0.8rc1 and submitting from tp-login.
> I am running with a DOEgrids cert in the OSG VO.
> I *think* the issue is that when a gt2 jobs on this vo runs with a login
> shell, it doesnt get java in its path.
> When I run /bin/sh *without* the "-l" option, under globus, I do get a java
> in my path.
