[Swift-devel] Coasters failing on Teraport - cant find Java?
Ben Clifford
benc at hawaga.org.uk
Tue Feb 3 11:00:38 CST 2009
On Tue, 3 Feb 2009, Michael Wilde wrote:
> .coasterinit is a more flexible alternative to a per-site option that points
> to java. Im not sure which is better.
Flexible in that you can run arbitrary commands; however, less flexible in
that it is per-remote-uid, not per-run. per-site options are implicitly
also settable per-run (and hence per-submit-side-user,
per-installed-swift-version, and the like)
