[Swift-devel] Coasters failing on Teraport - cant find Java?
    Mihael Hategan
    hategan at mcs.anl.gov
    Mon Feb  2 11:58:11 CST 2009
On Mon, 2009-02-02 at 17:38 +0000, Ben Clifford wrote:
> On Tue, 27 Jan 2009, Michael Wilde wrote:
> > 1) On OSG sites, the jobmanager(s) are modified to inset OSG env vars and set
> > the PATH to contain OSG stuff. So if you do a globus-job-run of
> This isn't universal OSG behaviour. Some sites give you
> PATH=/bin:/usr/bin
Which happens to be useless.
I suppose, for those sites, we need have an option to explicitly set
where Java is, if that doesn't already work somehow.
