[Swift-devel] gridftp issue in running oops swift script on queenbee
Wenjun Wu
wwj at ci.uchicago.edu
Tue Dec 8 13:14:00 CST 2009
I wrote a simple script doing the cat on Queenbeen and it worked fine.
type MFile;
(MFile outfile) runcat(MFile infile){
app {
rcat @infile stdout=@filename(outfile);
MFile infile <single_file_mapper;file="test-input">;
MFile outfile <single_file_mapper;file="test-output">;
outfile=runcat(infile);
What I really want to try as a next step is to run the ItFixInit as a
local task instead of a remote one. It could avoid the weird issue.
Wenjun
> Wenjun, can you try to run a simple script consisting of a single cat
> command, to make it easy to see what Swift is doing on Queenbee?
> It looks to me like something is acting strange in the interaction
> between Swift and Queenbee's gridftp server.
> Mihael: looking at the original logs I was perplexed to see that Swift
> could create the remote directories but not remove them. Almost as if
> the remove command was using a pathname that the grodftp server
> couldnt see.
> Wenjun tried a manual globus-url-copy to what we thought was a very
> similar path, and from the command line (with Swift's globus-url-copy)
> it was able to fetch individual files. So it seems that his workdir is
> visible to Queenbee's gridftp by what *seemed* like the expected path.
> It would be interesting to try uberftp and see if dirs and files can
> be removed. You'd need a host that has it; not sure if its in the
> teragrid toolkit or not. Its in the OSG client stack. Maybe can
> download it separately.
> - Mike
> On 12/3/09 11:25 PM, Mihael Hategan wrote:
>> Doesn't look like there are any files there created by the compute
>> nodes. Are you sure that filesystem is visible from the compute node?
>> On Thu, 2009-12-03 at 23:03 -0600, Wenjun Wu wrote:
>>> |-info
>>> |-kickstart
>>> |-shared
>>> |---dev
>>> |---output
>>> |-----T1af7
>>> |-------R00
>>> |---sandbox
>>> |-----wwj
>>> |-------oops
>>> |---------input
>>> |-----------fasta
>>> |-----------native
>>> |-----------rama
>>> |-----------secseq
>>> |-status
>>> |---f
>>> |---h
>>> |---j
>>>> On Thu, 2009-12-03 at 16:31 -0600, Wenjun Wu wrote:
>>>>> Under the info directory, there is no file left.
>>>>> ls -lt oops-20091202-1700-vmh5dnd3/info
>>>>> total 0
>>>>> And actually the j/ItFixInit-jjpe3bk was created at the same level
>>>>> as oops-20091202-1700-vmh5dnd3.
>>>> Can you do a "tree" in oops-20091202-1700-vmh5dnd3 and paste that?
>> Swift-devel mailing list
>> Swift-devel at ci.uchicago.edu
>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
