[Swift-devel] gridftp issue in running oops swift script on queenbee
Michael Wilde
wilde at mcs.anl.gov
Fri Dec 4 11:18:11 CST 2009
Wenjun, can you try to run a simple script consisting of a single cat
command, to make it easy to see what Swift is doing on Queenbee?
It looks to me like something is acting strange in the interaction
between Swift and Queenbee's gridftp server.
Mihael: looking at the original logs I was perplexed to see that Swift
could create the remote directories but not remove them. Almost as if
the remove command was using a pathname that the grodftp server couldnt see.
Wenjun tried a manual globus-url-copy to what we thought was a very
similar path, and from the command line (with Swift's globus-url-copy)
it was able to fetch individual files. So it seems that his workdir is
visible to Queenbee's gridftp by what *seemed* like the expected path.
It would be interesting to try uberftp and see if dirs and files can be
removed. You'd need a host that has it; not sure if its in the teragrid
toolkit or not. Its in the OSG client stack. Maybe can download it
separately.
- Mike
On 12/3/09 11:25 PM, Mihael Hategan wrote:
> Doesn't look like there are any files there created by the compute
> nodes. Are you sure that filesystem is visible from the compute node?
> On Thu, 2009-12-03 at 23:03 -0600, Wenjun Wu wrote:
>> |-info
>> |-kickstart
>> |-shared
>> |---dev
>> |---output
>> |-----T1af7
>> |-------R00
>> |---sandbox
>> |-----wwj
>> |-------oops
>> |---------input
>> |-----------fasta
>> |-----------native
>> |-----------rama
>> |-----------secseq
>> |-status
>> |---f
>> |---h
>> |---j
>>> On Thu, 2009-12-03 at 16:31 -0600, Wenjun Wu wrote:
>>>> Under the info directory, there is no file left.
>>>> ls -lt oops-20091202-1700-vmh5dnd3/info
>>>> total 0
>>>> And actually the j/ItFixInit-jjpe3bk was created at the same level as
>>>> oops-20091202-1700-vmh5dnd3.
>>> Can you do a "tree" in oops-20091202-1700-vmh5dnd3 and paste that?
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
