[Swift-devel] RE: [Swift-user] Execution error
    Glen Hocky
    hockyg at uchicago.edu
    Thu Apr 30 16:13:34 CDT 2009
I have the identical response on ranger. It started yesterday evening.
Possibly a problem that the TACC folks need to fix?
Glen
Yue, Chen - BMD wrote:
> Hi Michael,
> Thank you for the advices. I tested ranger with 1 job and new
> specifications of maxwalltime. It shows the following error message. I
> don't know if there is other problem with my setup. Thank you!
> [yuechen at communicado PTMap2]$ swift PTMap2-unmod.swift -sites.file
> sites.xml -tc.file tc.data
> Swift 0.9rc2 swift-r2860 cog-r2388
> RunID: 20090430-1559-2vi6x811
> Progress:
> Progress:  Stage in:1
> Progress:  Submitting:1
> Progress:  Submitted:1
> Progress:  Active:1
> Failed to transfer wrapper log from
> PTMap2-unmod-20090430-1559-2vi6x811/info/i on ranger
> Progress:  Active:1
> PTMap2-unmod-20090430-1559-2vi6x811/info/k on ranger
> Progress:  Active:1
> PTMap2-unmod-20090430-1559-2vi6x811/info/m on ranger
> Progress:  Failed:1
> Execution failed:
>         Exception in PTMap2:
> Arguments: [e04.mzXML, ./seqs-ecolik12/fasta01, inputs-unmod.txt,
> parameters.txt]
> Host: ranger
> Directory: PTMap2-unmod-20090430-1559-2vi6x811/jobs/m/PTMap2-mbe6m5aj
> stderr.txt:
> stdout.txt:
> Caused by:
>         Failed to start worker:
> null
> null
> org.globus.gram.GramException: The job manager detected an invalid
> script response
>         at
> org.globus.cog.abstraction.impl.execution.gt2.JobSubmissionTaskHandler.statusChanged(JobSubmissionTaskHandler.java:530)
>         at org.globus.gram.GramJob.setStatus(GramJob.java:184)
>         at
> org.globus.gram.GramCallbackHandler.run(CallbackHandler.java:176)
>         at java.lang.Thread.run(Thread.java:619)
> Cleaning up...
> Shutting down service at https://129.114.50.163:45562
> <https://129.114.50.163:45562>
> Got channel MetaChannel: 20903429 -> GSSSChannel-null(1)
> - Done
> Chen, Yue
> *From:* Michael Wilde [mailto:wilde at mcs.anl.gov]
> *Sent:* Thu 4/30/2009 3:02 PM
> *To:* Yue, Chen - BMD; swift-devel
> *Subject:* Re: [Swift-user] Execution error
> Back on list here (I only went off-list to discuss accounts, etc)
> The problem in the run below is this:
> 2009-04-30 14:29:41,265-0500 DEBUG vdl:execute2 APPLICATION_EXCEPTION
> jobid=PTMap2-abeii5aj - Application exception: Job cannot be run with
> the given max walltime worker constraint (task: 3000, \
> maxwalltime: 2400s)
> You have this on the ptmap app in your tc.data:
> globus::maxwalltime=50
> But you only gave coasters 40 mins per coaster worker. So its
> complaining that it cant run a 50 minute job in a 40 minute (max)
> coaster worker. ;)
> I mentioned in a prior mail that you need to set the two time vals in
> your sites.xml entry; thats what you need to do next, now.
> change the coaster time in your sites.xml to:
>      key="coasterWorkerMaxwalltime">00:51:00</profile>
> If you have more info on the variability of your ptmap run times, send
> that to the list, and we can discuss how to handle.
> (NOTE: doing grp -i of the log for "except" or scanning for "except"
> with an editor will often locate the first "exception" that your job
> encountered. Thats how I found the error above).
> Also, Yue, for testing new sites, or for validating that old sites still
> work, you should create the smallest possible ptmap workflow - 1 job if
> that is possible - and verify that this works.  Then say 10 jobs to make
> sure scheduling etc is sane.  Then, send in your huge jobs.
> With only 1 job, its easier to spot the errors in the log file.
> - Mike
> On 4/30/09 2:34 PM, Yue, Chen - BMD wrote:
> > Hi Michael,
> > I run into the same messages again when I use Ranger:
> > Progress:  Selecting site:146  Stage in:25  Submitting:15  Submitted:821
> > Failed but can retry:16
> > PTMap2-unmod-20090430-1428-v0c5di5c/info/q on ranger
> > PTMap2-unmod-20090430-1428-v0c5di5c/info/l on ranger
> > Progress:  Selecting site:146  Stage in:3  Submitting:1  Submitted:857
> > PTMap2-unmod-20090430-1428-v0c5di5c/info/v on ranger
> > PTMap2-unmod-20090430-1428-v0c5di5c/info/b on ranger
> > PTMap2-unmod-20090430-1428-v0c5di5c/info/0 on ranger
> > PTMap2-unmod-20090430-1428-v0c5di5c/info/a on ranger
> > PTMap2-unmod-20090430-1428-v0c5di5c/info/8 on ranger
> > PTMap2-unmod-20090430-1428-v0c5di5c/info/7 on ranger
> > PTMap2-unmod-20090430-1428-v0c5di5c/info/4 on ranger
> > PTMap2-unmod-20090430-1428-v0c5di5c/info/x on ranger
> > PTMap2-unmod-20090430-1428-v0c5di5c/info/3 on ranger
> > The log for the search is at :
> > /home/yuechen/PTMap2/PTMap2-unmod-20090430-1428-v0c5di5c.log
> > The sites.xml I have is:
> >  <pool handle="ranger">
> >      <execution provider="coaster"
> >                 url="gatekeeper.ranger.tacc.teragrid.org"
> >                 jobManager="gt2:gt2:SGE"/>
> >      <gridftp url="gsiftp://gridftp.ranger.tacc.teragrid.org:2811/" />
> >      <profile namespace="env"
> >               key="SWIFT_JOBDIR_PATH">/tmp/yuechen/jobdir</profile>
> >      <profile namespace="globus" key="project">TG-CCR080022N</profile>
> >      <profile namespace="globus" key="coastersPerNode">16</profile>
> >      <profile namespace="globus" key="queue">development</profile>
> >               key="coasterWorkerMaxwalltime">00:40:00</profile>
> >      <profile namespace="globus" key="maxwalltime">31</profile>
> >      <profile namespace="karajan" key="initialScore">50</profile>
> >      <profile namespace="karajan" key="jobThrottle">10</profile>
> >      <workdirectory>/work/01164/yuechen/swiftwork</workdirectory>
> >  </pool>
> > The tc.data I have is:
> > ranger          PTMap2
> > /share/home/01164/yuechen/PTMap2/PTMap2         INSTALLED
> > INTEL32::LINUX  globus::maxwalltime=50
> > I'm using swift 0.9 rc2
> > Thank you very much for help!
> > Chen, Yue
> > *Sent:* Thu 4/30/2009 2:05 PM
> > On 4/30/09 1:51 PM, Yue, Chen - BMD wrote:
> >  > Hi Michael,
> >  > When I tried to activate my account, I encountered the following
> error:
> >  > "Sorry, this account is in an invalid state. You may not activate
> your
> >  > at this time."
> >  > I used the username and password from TG-CDA070002T. Should I use a
> >  > different password?
> > If you can already login to Ranger, then you are all set - you must have
> > done this previously.
> > I thought you had *not*, because when I looked up your login on ranger
> > ("finger yuechen") it said "never logged in". But seems like that info
> > is incorrect.
> > If you have ptmap compiled, seems like you are almost all set.
> > Let me know if it works.
> > - Mike
> >  > Thanks!
> >  > Chen, Yue
> >  > *Sent:* Thu 4/30/2009 1:07 PM
> >  > *Cc:* swift user
> >  > Yue, use this XML pool element to access ranger:
> >  >      <gridftp
> >  >      <workdirectory>/work/00306/tg455797/swiftwork</workdirectory>
> >  >    </pool>
> >  > You will need to also do these steps:
> >  > Go to this web page to enable your Ranger account:
> >  > https://tas.tacc.utexas.edu/TASMigration/AccountActivation.aspx
> >  > Then login to Ranger via the TeraGrid portal and put your ssh keys in
> >  > place (assuming you use ssh keys, which you should)
> >  > While on Ranger, do this:
> >  > echo $WORK
> >  > mkdir $work/swiftwork
> >  > and put the full path of your $WORK/swiftwork directory in the
> >  > <workdirectory> element above. (My login is tg455etc, yours is
> yuechen)
> >  > Then scp your code to Ranger and compile it.
> >  > Then create a tc.data entry for your ptmap app
> >  > Next, set your time values in the sites.xml entry above to suitable
> >  > values for Ranger. You'll need to measure times, but I think you will
> >  > find Ranger about twice as fast as Mercury for CPU-bound jobs.
> >  > The values above were set for one app job per coaster. I think
> you can
> >  > probably do more.
> >  > If you estimate a run time of 5 minutes, use:
> >  >               key="coasterWorkerMaxwalltime">00:30:00</profile>
> >  >      <profile namespace="globus" key="maxwalltime">5</profile>
> >  > Other people on the list - please sanity check what I suggest here.
> >  > - Mike
> >  > On 4/30/09 12:40 PM, Michael Wilde wrote:
> >  >  > I just checked - TG-CDA070002T has indeed expired.
> >  >  > The best for now is to move to use (only) Ranger, under this
> account:
> >  >  > TG-CCR080022N
> >  >  > I will locate and send you a sites.xml entry in a moment.
> >  >  > You need to go to a web page to activate your Ranger login.
> >  >  > Best to contact me in IM and we can work this out.
> >  >  > - Mike
> >  >  > On 4/30/09 12:23 PM, Michael Wilde wrote:
> >  >  >> Also, what account are you running under? We may need to change
> > you to
> >  >  >> a new account - as the OSG Training account expires today.
> >  >  >> If that happend at Noon, it *might* be the problem.
> >  >  >> - Mike
> >  >  >> On 4/30/09 12:08 PM, Yue, Chen - BMD wrote:
> >  >  >>> Hi,
> >  >  >>> I came back to re-run my application on NCSA Mercury which was
> > tested
> >  >  >>> successfully last week after I just set up coasters with
> swift 0.9,
> >  >  >>> but I got many messages like the following:
> >  >  >>> Progress:  Stage in:219  Submitting:803  Submitted:1
> >  >  >>> Progress:  Stage in:129  Submitting:703  Submitted:190 Failed
> > but can
> >  >  >>> retry:1
> >  >  >>> Progress:  Stage in:38  Submitting:425  Submitted:556 Failed
> but can
> >  >  >>> retry:4
> >  >  >>> PTMap2-unmod-20090430-1203-r19dxq10/info/h on NCSA_MERCURY
> >  >  >>> PTMap2-unmod-20090430-1203-r19dxq10/info/j on NCSA_MERCURY
> >  >  >>> PTMap2-unmod-20090430-1203-r19dxq10/info/p on NCSA_MERCURY
> >  >  >>> PTMap2-unmod-20090430-1203-r19dxq10/info/1 on NCSA_MERCURY
> >  >  >>> PTMap2-unmod-20090430-1203-r19dxq10/info/b on NCSA_MERCURY
> >  >  >>> PTMap2-unmod-20090430-1203-r19dxq10/info/c on NCSA_MERCURY
> >  >  >>> Progress:  Stage in:1  Submitted:1013  Active:1 Failed but can
> > retry:8
> >  >  >>> Progress:  Submitted:1011  Active:1 Failed but can retry:11
> >  >  >>> The log file for the successful run last week is ;
> >  >  >>> /home/yuechen/PTMap2/PTMap2-unmod-20090422-1216-4s3037gf.log
> >  >  >>> The log file for the failed run is :
> >  >  >>> /home/yuechen/PTMap2/PTMap2-unmod-20090430-1151-rf2uuhb7.log
> >  >  >>> I don't think I did anything different, so I don't know why this
> > time
> >  >  >>> they failed. The sites.xml for Mercury is:
> >  >  >>>  <pool handle="NCSA_MERCURY">
> >  >  >>>     <gridftp url="gsiftp://gridftp-hg.ncsa.teragrid.org"/>
> url="grid-hg.ncsa.teragrid.org"
> >  >  >>> jobManager="gt2:PBS"/>
> <workdirectory>/gpfs_scratch1/yuechen/swiftwork</workdirectory>
> >  >  >>>     <profile namespace="globus" key="queue">debug</profile>
> >  >  >>>  </pool>
> >  >  >>> Thank you for help!
> >  >  >>> Chen, Yue
> >  >  >>> This email is intended only for the use of the individual or
> entity
> >  >  >>> to which it is addressed and may contain information that is
> >  >  >>> privileged and confidential. If the reader of this email
> message is
> >  >  >>> not the intended recipient, you are hereby notified that any
> >  >  >>> dissemination, distribution, or copying of this communication is
> >  >  >>> prohibited. If you have received this email in error, please
> notify
> >  >  >>> the sender and destroy/delete all copies of the transmittal.
> > Thank you.
> >  >  >>> _______________________________________________
> >  >  >>> Swift-user mailing list
> >  >  >>> Swift-user at ci.uchicago.edu
> >  >  >>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
> entity to
> privileged and
> >  > confidential. If the reader of this email message is not the intended
> >  > recipient, you are hereby notified that any dissemination,
> distribution,
> >  > or copying of this communication is prohibited. If you have received
> >  > this email in error, please notify the sender and destroy/delete all
> >  > copies of the transmittal. Thank you.
> > This email is intended only for the use of the individual or entity to
> > which it is addressed and may contain information that is privileged and
> > recipient, you are hereby notified that any dissemination, distribution,
> and confidential. If the reader of this email message is not the
> intended recipient, you are hereby notified that any dissemination,
> distribution, or copying of this communication is prohibited. If you
> have received this email in error, please notify the sender and
> destroy/delete all copies of the transmittal. Thank you.
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
