[Swift-devel] feature request
    Zhao Zhang
    zhaozhang at uchicago.edu
    Wed Apr 29 10:06:20 CDT 2009
Hi, Ben
I modified the existing swift-osg-ress-site-catalog, and generate a
sample sites.xml at CI network
/home/zzhang/swift_coaster/cog/modules/swift/tests/sites/condor-g/sample-sites.xml
Could you help me check if there is any known error in there? thanks.
zhao
Ben Clifford wrote:
> On Wed, 29 Apr 2009, Zhao Zhang wrote:
>> I am figuring out how to convert from VO Resouce Selector web page to valid
>> sites.xml.
> There is already a tool, swift-osg-ress-site-catalog to take OSG site
> information and make it into a sites.xml. That is a much better place for
> you to start at, I think. Look in the bin/ directory of a swift
> distribution. That already collects of the information you need.
>> Also, as I remembered, condor should use GT4, right? But we specify gt2 in the
>> above sites.xml, is this correct?
> No, you should use gt2 (that means gram2).
