[Swift-devel] feature request
    Zhao Zhang
    zhaozhang at uchicago.edu
    Wed Apr 29 09:44:56 CDT 2009
Hi, Ben
I am figuring out how to convert from VO Resouce Selector web page to
valid sites.xml.
Take renci-engagement as an example, the page is here
http://vors.grid.iu.edu/cgi-bin/index.cgi?region=0&VO=24&grid=1&dtype=0&res=387#SITELISTING
How could I infer the value of the following fields?
<workdirectory >/nfs/home/osgedu/benc</workdirectory>
<profile namespace="globus" key="jobType">grid</profile>
<profile namespace="globus" key="gridResource">gt2
belhaven-1.renci.org/jobmanager-fork</profile>
Also, as I remembered, condor should use GT4, right? But we specify gt2
in the above sites.xml, is this correct?
Thanks.
zhao
Ben Clifford wrote:
> OK. The tests with spaces/quotes/strange characters will fail whenever
> condor is used. As long as 061-cattwo and 130-fmri are successful, that is
> ok for now.
> Bug 200 in the Swift bugzilla may allow all the tests to work, when it is
> implemented (I am part way through).
> On Tue, 28 Apr 2009, Zhao Zhang wrote:
>> Hi, Ben
>> Unfortunately, the last swift workflow failed, I am attaching the log.
>> zhao
>>>> It worked, but there is an exception.
>>> OK. That's a known issue (or known to me and Mats at least) with the way
>>> that cleanup jobs are handled. I need to fix it, but it should not stop you
>>> testing lots of sites.
