[Swift-devel] progress stats lying
    Glen Hocky
    hockyg at uchicago.edu
    Tue Apr 28 13:05:37 CDT 2009
as a user, it seems very important to have accurate summary stats so you
can tell if anything is going wrong.
Mihael Hategan wrote:
> On Tue, 2009-04-28 at 07:15 +0000, Ben Clifford wrote:
>> On Tue, 28 Apr 2009, Ben Clifford wrote:
>>>> A possible solution is to add another state ("Checking status" or
>>>> something), that is triggered in Execute by a task completed event.
>> r2887 adds a checking status event in execute2, right after the
>> vdl:execute call. I think that is sufficient? or are you claiming that
>> something deeper in the execute layer is delaying things?
> It's probably better but not sufficient. With many threads there may be
> delays between the vdl:execute call completing and the next thing
> running may be visible.
> The problem is that swift may say that more jobs are active than known
> possible, which will raise eyebrows.
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
