[Swift-devel] several questions about coaster
Zhao Zhang
zhaozhang at uchicago.edu
Tue Apr 28 00:46:38 CDT 2009
Hi, Mihael
As I am going to test coaster deeply on various systems. I got several
questions regarding to the coaster infrastructure.
1. Scalability
From source code, I could tell that coaster is using TCP for task
transmission.(correct me if I am wrong) What is the largest
scale test we have done with coaster? I mean the ratio between
coaster dispatcher and the number of workers.
2. Usability
All tests I have tried with coaster were running together with
swift. That is a black box test for me. Is there any interface in coaster
that I could specify the number of workers and the wall time?
Also, is there a way for me to start coaster service and workers
separately and independently?
Besides, I am guessing coaster is using a dynamic provisioning
approach to request resources, is this correct? Which means coaster
will decide how many compute nodes to request according to the
number of jobs, and the length of jobs. If I run coaster in a super computer
context, can I ask coaster to hold a certain number of compute nodes
for a certain amount of time? (This somehow overlaps the first Q in
section 2)
3. Performance
Does coaster provide alternative interface other than the coaster
provider? Say if I want to test the dispatch rate of coaster, but don't
want to
introduce swift overhead, which is a good way to start coaster?
Is there a coaster log that could show the number of active workers
currently registered with the coaster service, how many jobs are running,
how many jobs returned successful, and etc.?
4. Dispatch Algorithm
Does coaster use a scoring algorithm for dispatching jobs? Which
means coaster service keeps scores for every workers, and dispatch jobs
based on those scores? Is there an alternative way, say FIFO algorithm?
5. Reliability
I know that if a job failed, swift could resend the same job. But
does coaster have any error recovery mechanism built in?
So far so many questions, thanks for you patience. I will have more as
going on with the testing. :-)
best wishes
zhao
