[Swift-devel] feature request
    Zhao Zhang
    zhaozhang at uchicago.edu
    Fri Apr 24 12:52:02 CDT 2009
Hi, All
As I got mapped on gwynn, I redid the tests. The results are
All language behaviour tests passed
These sites failed: coaster/tgncsa-hg-coaster-pbs-gram2.xml
coaster/tgncsa-hg-coaster-pbs-gram4.xml
These sites worked: coaster/coaster-local.xml
coaster/gwynn-coaster-gram2-gram2-condor.xml
coaster/gwynn-coaster-gram2-gram2-fork.xml
coaster/renci-engage-coaster.xml coaster/teraport-gt2-gt2-pbs.xml
coaster/uj-pbs-gram2.xml
Logs could be found at
/home/zzhang/swift_coaster/cog/modules/swift/tests/sites/log_all on CI
network.
zhao
Zhao Zhang wrote:
> Hi, again
> the test on teraport is successful, here is the log
> zhao
> testing site configuration: coaster/teraport-gt2-gt2-pbs.xml
> Removing files from previous runs
> Running test 061-cattwo at Thu Apr 23 11:27:19 CDT 2009
> Swift 0.9rc2 swift-r2860 cog-r2388
> RunID: 20090423-1127-aluxx4m9
> Progress:
> Progress:  Stage in:1
> Progress:  Submitted:1
> Progress:  Active:1
> Progress:  Finished successfully:1
> Final status:  Finished successfully:1
> Cleaning up...
> Shutting down service at https://128.135.125.118:57080
> Got channel MetaChannel: 2129305 -> GSSSChannel-null(1)
> - Done
> expecting 061-cattwo.out.expected
> checking 061-cattwo.out.expected
> Skipping exception test due to test configuration
> Test passed at Thu Apr 23 11:57:39 CDT 2009
> Running test 130-fmri at Thu Apr 23 11:57:39 CDT 2009
> RunID: 20090423-1157-r8sarc77
> Progress:
> Progress:  Selecting site:2  Initializing site shared directory:1
> Stage in:1
> Progress:  Selecting site:2  Stage in:1  Submitting:1
> Progress:  Selecting site:2  Submitting:1  Submitted:1
> Progress:  Selecting site:2  Submitted:2
> Progress:  Selecting site:2  Submitted:1  Active:1
> Progress:  Selecting site:2  Active:1  Stage out:1
> Progress:  Selecting site:1  Stage in:1  Stage out:1  Finished
> successfully:1
> Progress:  Submitted:1  Stage out:1  Finished successfully:2
> Progress:  Active:1  Finished successfully:4
> Progress:  Submitting:2  Submitted:1  Finished successfully:5
> Progress:  Active:2  Stage out:1  Finished successfully:5
> Progress:  Submitted:1  Stage out:2  Finished successfully:8
> Final status:  Finished successfully:11
> Cleaning up...
> Shutting down service at https://128.135.125.118:52773
> Got channel MetaChannel: 28761475 -> GSSSChannel-null(1)
> - Done
> expecting 130-fmri.0000.jpeg.expected 130-fmri.0001.jpeg.expected
> 130-fmri.0002.jpeg.expected
> checking 130-fmri.0000.jpeg.expected
> checking 130-fmri.0001.jpeg.expected
> checking 130-fmri.0002.jpeg.expected
> Test passed at Thu Apr 23 12:04:47 CDT 2009
> Running test 103-quote at Thu Apr 23 12:04:47 CDT 2009
> RunID: 20090423-1204-sjzpkfd3
> Progress:
> Progress:  Active:1
> Cleaning up...
> Shutting down service at https://128.135.125.118:40813
> Got channel MetaChannel: 28500325 -> GSSSChannel-null(1)
> - Done
> expecting 103-quote.out.expected
> checking 103-quote.out.expected
> Test passed at Thu Apr 23 12:05:05 CDT 2009
> Running test 1032-singlequote at Thu Apr 23 12:05:05 CDT 2009
> RunID: 20090423-1205-x2d55af3
> Progress:
> Progress:  Active:1
> Cleaning up...
> Shutting down service at https://128.135.125.118:44126
> Got channel MetaChannel: 18100302 -> GSSSChannel-null(1)
> - Done
> expecting 1032-singlequote.out.expected
> checking 1032-singlequote.out.expected
> Test passed at Thu Apr 23 12:05:22 CDT 2009
> Running test 1031-quote at Thu Apr 23 12:05:22 CDT 2009
> RunID: 20090423-1205-5aa1ko4e
> Progress:
> Progress:  Active:1
> Cleaning up...
> Shutting down service at https://128.135.125.118:43759
> Got channel MetaChannel: 19002607 -> GSSSChannel-null(1)
> - Done
> expecting 1031-quote.*.expected
> No expected output files specified for this test case - not checking
> output.
> Test passed at Thu Apr 23 12:05:38 CDT 2009
> Running test 1033-singlequote at Thu Apr 23 12:05:38 CDT 2009
> RunID: 20090423-1205-8nopyujc
> Progress:
> Progress:  Active:1
> Cleaning up...
> Shutting down service at https://128.135.125.118:39924
> Got channel MetaChannel: 31196317 -> GSSSChannel-null(1)
> - Done
> expecting 1033-singlequote.out.expected
> checking 1033-singlequote.out.expected
> Test passed at Thu Apr 23 12:05:56 CDT 2009
> Running test 141-space-in-filename at Thu Apr 23 12:05:56 CDT 2009
> RunID: 20090423-1205-aalqz1c4
> Progress:
> Progress:  Active:1
> Cleaning up...
> Shutting down service at https://128.135.125.118:60177
> Got channel MetaChannel: 4728458 -> GSSSChannel-null(1)
> - Done
> expecting 141-space-in-filename.space here.out.expected
> checking 141-space-in-filename.space here.out.expected
> Test passed at Thu Apr 23 12:06:15 CDT 2009
> Running test 142-space-and-quotes at Thu Apr 23 12:06:15 CDT 2009
> RunID: 20090423-1206-8617gag1
> Progress:
> Stage in:1
> Progress:  Selecting site:2  Active:1  Finished successfully:1
> Progress:  Stage out:1  Finished successfully:3
> Final status:  Finished successfully:4
> Cleaning up...
> Shutting down service at https://128.135.125.118:57945
> Got channel MetaChannel: 16387060 -> GSSSChannel-null(1)
> - Done
> expecting 142-space-and-quotes.2" space ".out.expected
> 142-space-and-quotes.3' space '.out.expected
> 142-space-and-quotes.out.expected 142-space-and-quotes. space
> .out.expected
> checking 142-space-and-quotes.2" space ".out.expected
> checking 142-space-and-quotes.3' space '.out.expected
> checking 142-space-and-quotes.out.expected
> checking 142-space-and-quotes. space .out.expected
> Test passed at Thu Apr 23 12:06:35 CDT 2009
> Zhao Zhang wrote:
>> Hi, Ben
>> Ben Clifford wrote:
>>> On Thu, 23 Apr 2009, Zhao Zhang wrote:
>>>> Error 1: This is related to CI network setting,
>>>> /etc/grid-security/hostcert.pem. Could anyone help on this? Who
>>>> should I
>>>> contact?
>>> fletch is broken. But try changing those sites files to use
>>> gwynn.bsd.uchicago.edu instead.
>>>> Error 2: My certificate is not enabled on teraport, As Mike and I
>>>> talked last
>>>> night, "certificate revocation list" on CI network is misconfigured.
>>> This looks more like a permissions problem - the directory being
>>> used in the sites.xml file for that test does not exist and you do
>>> not have permission to create it.
>>> In r2874 I have changes tests/sites/coaster/teraport-gt2-gt2-pbs.xml
>>> to use a different path that should work for you now.
>> I tried this out, it failed, then I increased the wall-time to 15
>> minutes in the coaster/teraport-gt2-gt2-pbs.xml  file.
>> And I am waiting now.
>> zhao
>> [zzhang at communicado sites]$ ./run-site coaster/teraport-gt2-gt2-pbs.xml
>> Running test 061-cattwo at Thu Apr 23 11:12:09 CDT 2009
>> RunID: 20090423-1112-6jqlxfcf
>> Progress:
>> Failed to transfer wrapper log from
>> 061-cattwo-20090423-1112-6jqlxfcf/info/q on teraport
>> 061-cattwo-20090423-1112-6jqlxfcf/info/s on teraport
>> 061-cattwo-20090423-1112-6jqlxfcf/info/u on teraport
>> Progress:  Failed:1
>> Execution failed:
>>        Exception in cat:
>> Arguments: [061-cattwo.1.in, 061-cattwo.2.in]
>> Host: teraport
>> Directory: 061-cattwo-20090423-1112-6jqlxfcf/jobs/u/cat-umlmrs9j
>> stderr.txt:
>> stdout.txt:
>> Caused by:
>>        Job cannot be run with the given max walltime worker
>> constraint (task: 600, maxwalltime: 300s)
>> Cleaning up...
>> Shutting down service at https://128.135.125.118:58204
>> Got channel MetaChannel: 1297642 -> GSSSChannel-null(1)
>> - Done
>> SWIFT RETURN CODE NON-ZERO - test 061-cattwo
>>>> Error 3 & Error 4: I am not active on tgncsa site. Mike said he
>>>> needed to add
>>>> me to another group.
>>> yes.
>>> Do you have the list from the end of your test run about which sites
>>> worked and which did not?
>> Swift-devel mailing list
>> Swift-devel at ci.uchicago.edu
>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
