[Swift-devel] [Bug 202] New: ticker.disable and -tui parameters should merge into single display mode choice
    bugzilla-daemon at mcs.anl.gov
    Fri Apr 24 07:53:07 CDT 2009
https://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=202
           Summary: ticker.disable and -tui parameters should merge into
           Product: Swift
           Version: unspecified
          Platform: PC
        OS/Version: Mac OS
            Status: NEW
          Severity: enhancement
          Priority: P2
         Component: General
        AssignedTo: benc at hawaga.org.uk
        ReportedBy: benc at hawaga.org.uk
The output form of swift is controlled by both the ticker.disable config
propery and -tui command line option. These should merge into a single
parameter allowing the output display format to be chosen
(none, ticker, tui).
Configure bugmail: https://bugzilla.mcs.anl.gov/swift/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are watching the assignee of the bug.
You are watching the reporter.
