[Swift-devel] problem using queenbee
    Ben Clifford
    benc at hawaga.org.uk
    Thu Apr 23 01:44:26 CDT 2009
That error in qboutdir.2 looks like the same ftp error; but the below
paste from first.swift look like a different problem, with coasters.
On Thu, 23 Apr 2009, Glen Hocky wrote:
> results seem reproducible. output in qboutdir.2
> here is the result for first.swift
> logfile:  /home/hockyg/oops/swift/first-20090423-0135-gigv99m6.log
> > swift first.swift -tc.file qb.data -sites.file qb.xml
> > Swift 0.9rc2 swift-r2860 cog-r2388
> > RunID: 20090423-0135-gigv99m6
> > Progress:
> > Progress:  Stage in:1
> > Progress:  Submitted:1
> > Progress:  Active:1
> > Failed to transfer wrapper log from first-20090423-0135-gigv99m6/info/n on
> > qb
> > Progress:  Active:1
> > Failed to transfer wrapper log from first-20090423-0135-gigv99m6/info/p on
> > qb
> > Progress:  Active:1
> > Failed to transfer wrapper log from first-20090423-0135-gigv99m6/info/r on
> > qb
> > Progress:  Failed:1
> > Execution failed:
> >         Exception in echo:
> > Arguments: [Hello, world!]
> > Host: qb
> > Directory: first-20090423-0135-gigv99m6/jobs/r/echo-r4sk4s9j
> > stderr.txt:
> > stdout.txt:
> > Caused by:
> >         Failed to start worker: Worker ended prematurely
> > Cleaning up...
> > Shutting down service at https://208.100.92.21:46927
> > Got channel MetaChannel: 18653132 -> GSSSChannel-null(1)
> > - Done
> > > However, i'm having odd errors on queenbee. All files are in
> > > > /home/hockyg/oops/swift/output/qboutdir.1
> > > on ci home.
> > > Any idea what's wrong?
> > Lots of problems with gridftp, it looks like. There are lots of messages
> > like this:
> > org.globus.ftp.exception.DataChannelException: setPassive() must match
> > store() and setActive() - retrieve()  (error code 2)
> > in your most recent log file oops-20090422-2354-v1g3l76g.log in that
> > directory.
> > Is thsi repeatable with the same swiftscript?
> > Does examples/swift/first.swift run ok with that sites file?
