[Swift-devel] Avoid copy of local files to work directory?
    Gabri Turcu
    gabri.turcu at gmail.com
    Thu Apr 23 01:32:58 CDT 2009
Hi Ben,
Thank you for your quick response and your help. I have plots at
http://people.cs.uchicago.edu/~gabri/
The larger run of ~16hours (300 patterns searched against 100k files) is at
http://people.cs.uchicago.edu/~gabri/report-count-20090416-2119-s03yn299/
and the log file is at CI at
/home/gabri/swift-0.8/examples/swift/newslabex/count/logs/count-20090416-2119-s03yn299.log
Smaller runs (6 patterns against 20k files) are also in
http://people.cs.uchicago.edu/~gabri/concurrent_mapper/
and http://people.cs.uchicago.edu/~gabri/simple_mapper/
Thanks a lot.
Best,
Gabri
On Thu, Apr 23, 2009 at 1:13 AM, Ben Clifford <benc at hawaga.org.uk> wrote:
> On Wed, 22 Apr 2009, Gabri Turcu wrote:
> > I followed the steps at
> > http://mail.ci.uchicago.edu/pipermail/swift-devel/2008-April/002931.html
> > but could not recompile swift after adding the provider. I think I may
> not
> > using the right version of swift (Swift 0.8 swift-r2448 cog-r2261)?
> Yes, that is a version mismatch - the provider API has changed a little.
> I will fix it for you.
> In the meantime, do you have log files (and wrapper log files (-info
> files)) for one of the runs that you are experimenting on - I would like
> to see the timings of individual pieces.
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20090423/2d5729f5/attachment.html>
