[Swift-devel] Coaster capabilities for release 0.9
Ian Foster foster at anl.gov
Tue Apr 21 16:16:36 CDT 2009
Is it possible to argue for simplicity in these algorithms?
E.g., if I want to submit against an allocation, I should be able to
do that, and not have the algorithm second-guess me and do something
different.
Having more complex things is ok, too, as long as they can easily be
turned off--or (my recommendation) require that they be turned on
explicitly.
Ian.
On Apr 21, 2009, at 3:02 PM, Mihael Hategan wrote:
> On Tue, 2009-04-21 at 14:12 -0500, Michael Wilde wrote:
>>> Which should I rather do now, continue implementing block
>>> allocations,
>>> or sort out discussions about coasters from the mailing list?
>> You should do this:
>> First send a sentence or two on how block allocations are going:
>> whats
>> involved, and how long you think they will take till checked in. What
>> kind of testing will be required to ensure functional and stable.
> I haven't explicitly done so because I thought I mentioned this
> before.
> I have an algorithm that I tested with various loads and
> configurations.
> It can work with limited numbers of jobs, and pre-set allocations
> (though there are some tweaks there that are still needed - a major
> one
> being when to choose pre-existing allocations instead of automated
> allocations; for example, if the pre-existing allocation is tomorrow,
> and I submit now, I'd presumably want some jobs to be started before
> tomorrow).
> I need to now plug that into the rest of the coaster code (this is the
> part I'm doing right now), find ways to specify parameters in the
> sites
> file, efficiently ship those parameters remotely, and do some basic
> testing. I estimate that to take somewhere in the range of one to two
> weeks of development time, but that's not with very high confidence.
> The kind of testing needed to ensure stability is not different from
> what we've discussed and what we already know: we'll need to run
> synthetic tests on various sites, and we'll need to run existing
> applications on various sites. This is not new.
>> Then continue developing them.
>> Between now and Friday, do the list I asked for.
>>> (i.e. would you please let me do my job?)
>> Yes.
>> I know development takes concentration. To achieve that, you manage
>> your
>> time, and the rate at which you read and answer email or take any
>> other
>> interrupts.
>> If something needs immediate attention, I or others say so, or your
>> best
>> judgment does. If not, it doesn't, but needs eventual attention.
>> A list of coaster issues was started on swift-devel Feb 13:
>> http://mail.ci.uchicago.edu/pipermail/swift-devel/2009-February/004511.html
> There are 4 issues there:
> - bootstrap issues (these are solved - this was discussed on the
> mailing
> list)
> - sites.xml attribute for java - the priority of this has become lower
> because the detection is done better now, but it should probably still
> be implemented (this was also on the mailing list as far as I can
> remember; also, I think one can specify JAVA_HOME or make sure java is
> in the path using the environment or otherwise)
> - service on the worker node - after block allocations, unless Ben
> does
> otherwise
> - the scalability problem - we're doing block allocations mainly to
> address this
>> A report on progress and summary of open design issues and work
>> remaining would benefit everyone.
>> Find a good stopping point in the next few days, then make list of
>> work
>> items and design and testing issues on coasters.
>> Then discuss and get feedback. Then develop what you listed. Then
>> repeat. That *is* your job.
> I wish :)
> Yep. We discussed, got feedback, and I was now developing. Discussing
> the same issues again was interfering with my developing. So let me
> re-state this: "I am now developing coaster block allocations. I will
> send feedback from time to time, when I have interesting things to
> send
> feedback about. I will probably have testable code in 1 to 2 weeks."
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20090421/02a456df/attachment.html>
