[Swift-devel] Planning next set of Swift features and releases
    Ben Clifford
    benc at hawaga.org.uk
    Tue Apr 21 13:58:56 CDT 2009
On Tue, 21 Apr 2009, Ben Clifford wrote:
> Yes, it does have significance. Though until you mentioned it today, I
> hadn't regard Swift as being
oops, missed half that paragraph. I really should write my emails in
order.
"hadn't regarded Swift as being specifically at a 1.0 stage (whatever that
means...)"
> > Also minor but going from 0.9 to 0.10 is odd.
> Not really. Lots of software uses . as a field separate for integers,
> rather than as a decimal-fraction indicator.
> > The significance of calling something 1.0 thought will extend to funding
> > issues, as our next NSF report will be due soon - June 1 I think - and
> > concurrently I need to go to NSF and other agencies for continued
> > funding, probably with an unsolicited proposal.
> OK. I don't really care what the versions are called as long as they are
> clearly ordered so if you have a preference for 0.9 + 2 to be 1.0 thats
> fine. Or 0.9 + 1 be 1.0.
> > My preference is to do 2 or more point releases in the next 16 weeks and
> > shoot for 1.0 by the end of August.
> 2 releases matches the existing release schedule for that time period,
> assuming that the first release candidate is released for each. Rough
> dates on that schedule are late June and late August (so 1.0 would be the
> august one)
> However, rushing to put less-well tested code into trunk is likely to
> break the first-rc-is-release goal, as well as lowering the quality of
> experience for people who build from SVN.
> > Condor-G support
> That exists in 0.9rc2, at least for regular job submission.
> >  - why iterate seems hard to use
> Post some stuff to swift-devel about htat.
