[Swift-devel] feature request
    Ben Clifford
    benc at hawaga.org.uk
    Tue Apr 21 12:41:45 CDT 2009
ok. now try:
 ./run-all coaster/
You will need to watch this occasionally because sometimes you might find
some sites hang rather than failing. You can kill the test for that site
by pressing ctrl-C; I think the test script will then move onto the next
site (but I am not sure).
On Tue, 21 Apr 2009, Zhao Zhang wrote:
> Ok, I found there is a pair of keys, with name "newcert.pem" and "newkey.pem",
> I could not remember when I renewed them. But yes, it is working
> [zzhang at communicado .globus]$ grid-proxy-init
> Your identity: DC=org,DC=doegrids,OU=People,CN=Zhao Zhang 385894
> Enter GRID pass phrase for this identity:        Creating proxy, please
> wait...
> Proxy verify OK
> Your proxy is valid until Wed Apr 22 00:33:38 CDT 2009
> [zzhang at communicado sites]$ ./run-site coaster/coaster-local.xml
> testing site configuration: coaster/coaster-local.xml
> Removing files from previous runs
> Running test 061-cattwo at Tue Apr 21 12:34:45 CDT 2009
> Swift 0.9rc2 swift-r2860 cog-r2388
> RunID: 20090421-1234-beqr2e0d
> Progress:
> Multiple entries found for cat on localhost. Using the first one
> Progress:  Submitted:1
> Progress:  Active:1
> Final status:  Finished successfully:1
> Cleaning up...
> Shutting down service at https://127.0.0.1:50003
> Got channel MetaChannel: 810427 -> GSSSChannel-null(1)
> - Done
> expecting 061-cattwo.out.expected
> checking 061-cattwo.out.expected
> Skipping exception test due to test configuration
> Test passed at Tue Apr 21 12:34:52 CDT 2009
> Running test 130-fmri at Tue Apr 21 12:34:52 CDT 2009
> RunID: 20090421-1234-0ig7ezt6
> Progress:
> Multiple entries found for touch on localhost. Using the first one
> Progress:  Selecting site:2  Submitting:1  Submitted:1
> Progress:  Selecting site:2  Submitted:1  Active:1
> Progress:  Selecting site:1  Stage in:1  Finished successfully:2
> Progress:  Submitted:1  Finished successfully:4
> Progress:  Submitted:3  Finished successfully:6
> Progress:  Submitted:1  Finished successfully:10
> Final status:  Finished successfully:11
> Cleaning up...
> Got channel MetaChannel: 27652339 -> GSSSChannel-null(1)
> - Done
> expecting 130-fmri.0000.jpeg.expected 130-fmri.0001.jpeg.expected
> 130-fmri.0002.jpeg.expected
> checking 130-fmri.0000.jpeg.expected
> checking 130-fmri.0001.jpeg.expected
> checking 130-fmri.0002.jpeg.expected
> Test passed at Tue Apr 21 12:35:05 CDT 2009
> Running test 103-quote at Tue Apr 21 12:35:05 CDT 2009
> RunID: 20090421-1235-fh6odt20
> Progress:
> Multiple entries found for echo on localhost. Using the first one
> Progress:  Active:1
> Cleaning up...
> Got channel MetaChannel: 32165316 -> GSSSChannel-null(1)
> - Done
> expecting 103-quote.out.expected
> checking 103-quote.out.expected
> Test passed at Tue Apr 21 12:35:12 CDT 2009
> Running test 1032-singlequote at Tue Apr 21 12:35:12 CDT 2009
> RunID: 20090421-1235-355iqmu2
> Progress:
> Progress:  Active:1
> Cleaning up...
> Got channel MetaChannel: 27362451 -> GSSSChannel-null(1)
> - Done
> expecting 1032-singlequote.out.expected
> checking 1032-singlequote.out.expected
> Test passed at Tue Apr 21 12:35:19 CDT 2009
> Running test 1031-quote at Tue Apr 21 12:35:19 CDT 2009
> RunID: 20090421-1235-kz20ns09
> Progress:
> Progress:  Active:1
> Cleaning up...
> - Done
> expecting 1031-quote.*.expected
> No expected output files specified for this test case - not checking output.
> Test passed at Tue Apr 21 12:35:26 CDT 2009
> Running test 1033-singlequote at Tue Apr 21 12:35:26 CDT 2009
> RunID: 20090421-1235-d82mk769
> Progress:
> Progress:  Active:1
> Cleaning up...
> Got channel MetaChannel: 3934565 -> GSSSChannel-null(1)
> - Done
> expecting 1033-singlequote.out.expected
> checking 1033-singlequote.out.expected
> Test passed at Tue Apr 21 12:35:33 CDT 2009
> Running test 141-space-in-filename at Tue Apr 21 12:35:33 CDT 2009
> RunID: 20090421-1235-53ylesn6
> Progress:
> Progress:  Active:1
> Cleaning up...
> - Done
> expecting 141-space-in-filename.space here.out.expected
> checking 141-space-in-filename.space here.out.expected
> Test passed at Tue Apr 21 12:35:40 CDT 2009
> Running test 142-space-and-quotes at Tue Apr 21 12:35:40 CDT 2009
> RunID: 20090421-1235-ko20j409
> Progress:
> Final status:  Finished successfully:4
> Cleaning up...
> Got channel MetaChannel: 15140795 -> GSSSChannel-null(1)
> - Done
> expecting 142-space-and-quotes.2" space ".out.expected 142-space-and-quotes.3'
> space '.out.expected 142-space-and-quotes.out.expected 142-space-and-quotes.
> space .out.expected
> checking 142-space-and-quotes.2" space ".out.expected
> checking 142-space-and-quotes.3' space '.out.expected
> checking 142-space-and-quotes.out.expected
> checking 142-space-and-quotes. space .out.expected
> Test passed at Tue Apr 21 12:35:50 CDT 2009
> All language behaviour tests passed
> Ben Clifford wrote:
> > zhao, on communicado please type:
> > grid-cert-info
> > and paste the results here.
> > Then type: grid-proxy-init and enter your password and paste the results.
