[Swift-devel] feature request
    Mihael Hategan
    hategan at mcs.anl.gov
    Tue Apr 21 12:12:46 CDT 2009
There's a bunch of "coaster-bootstrap-<id>.log" files in your home
directory, which give more details:
I see this in them:
Caused by: org.globus.gsi.GlobusCredentialException: [JGLOBUS-10]
Expired credentials (DC=org,DC=doegrids,OU=People,CN=Zhao Zhang 385894,C
N=1487316538).
On Tue, 2009-04-21 at 12:00 -0500, Zhao Zhang wrote:
> Hi, Ben
> I modified .soft, then ran the test, it failed with the same error as I
> had on surveyor:
> [zzhang at communicado sites]$ ./run-site coaster/coaster-local.xml
> testing site configuration: coaster/coaster-local.xml
> Removing files from previous runs
> Running test 061-cattwo at Tue Apr 21 11:57:16 CDT 2009
> Swift 0.9rc2 swift-r2860 cog-r2388
> RunID: 20090421-1157-hdc8m6c4
> Progress:
> Multiple entries found for cat on localhost. Using the first one
> Progress:  Submitted:1
> Failed to transfer wrapper log from
> 061-cattwo-20090421-1157-hdc8m6c4/info/l on localhost
> 061-cattwo-20090421-1157-hdc8m6c4/info/n on localhost
> Progress:  Stage in:1
> 061-cattwo-20090421-1157-hdc8m6c4/info/p on localhost
> Execution failed:
>         Exception in cat:
> Arguments: [061-cattwo.1.in, 061-cattwo.2.in]
> Host: localhost
> Directory: 061-cattwo-20090421-1157-hdc8m6c4/jobs/p/cat-pqfajp9j
> stderr.txt:
> stdout.txt:
> Caused by:
>         Could not submit job
> Caused by:
>         Could not start coaster service
> Caused by:
>         Task ended before registration was received.
> STDOUT:
> STDERR: which: no gmd5sum in
> (/home/zzhang/swift_coaster/cog/modules/swift/dist/swift-0.9rc2/bin:/home/zzhang/chirp/bin:/home/zzhang/xar/bin:/soft/java-1.5.0_06-sun-r1/bin:/soft/java-1.5.0_06-sun-r1/jre/bin:/usr/kerberos/bin:/bin:/usr/bin:/usr/X11R6/bin:/usr/local/bin:/software/common/softenv-1.6.0-r1/bin:/home/zzhang/bin/linux-rhel4-x86_64:/home/zzhang/bin:/soft/apache-ant-1.6.5-r1/bin:/software/common/cert-scripts-2-5.rev44-r1/bin:/soft/condor-6.8.1-r1/bin:/software/common/gx-map-0.5.3.3-r1/bin:/soft/globus-4.0.3-r1/bin:/soft/globus-4.0.3-r1/sbin)
> Caused by:
>         Job failed with an exit code of 1
> Cleaning up...
>  Done
> SWIFT RETURN CODE NON-ZERO - test 061-cattwo
> Ben Clifford wrote:
> > On Tue, 21 Apr 2009, Zhao Zhang wrote:
> >> Warning: -Xmx256M not understood. Ignoring.
> > This comes from a change that happened to communicado sometimes recently.
> > Modify your ~/.soft file so that you have the line:
> > +java-sun
> > before @default
> > Otherwise, you end up using gcj for java instead of a real java.
