[Swift-devel] feature request
    Zhao Zhang
    zhaozhang at uchicago.edu
    Tue Apr 21 12:00:03 CDT 2009
Hi, Ben
I modified .soft, then ran the test, it failed with the same error as I
had on surveyor:
[zzhang at communicado sites]$ ./run-site coaster/coaster-local.xml
testing site configuration: coaster/coaster-local.xml
Removing files from previous runs
Running test 061-cattwo at Tue Apr 21 11:57:16 CDT 2009
Swift 0.9rc2 swift-r2860 cog-r2388
RunID: 20090421-1157-hdc8m6c4
Progress:
Multiple entries found for cat on localhost. Using the first one
Progress:  Submitted:1
Failed to transfer wrapper log from
061-cattwo-20090421-1157-hdc8m6c4/info/l on localhost
061-cattwo-20090421-1157-hdc8m6c4/info/n on localhost
Progress:  Stage in:1
061-cattwo-20090421-1157-hdc8m6c4/info/p on localhost
Execution failed:
        Exception in cat:
Arguments: [061-cattwo.1.in, 061-cattwo.2.in]
Host: localhost
Directory: 061-cattwo-20090421-1157-hdc8m6c4/jobs/p/cat-pqfajp9j
stderr.txt:
stdout.txt:
Caused by:
        Could not submit job
Caused by:
        Could not start coaster service
Caused by:
        Task ended before registration was received.
STDOUT:
STDERR: which: no gmd5sum in
(/home/zzhang/swift_coaster/cog/modules/swift/dist/swift-0.9rc2/bin:/home/zzhang/chirp/bin:/home/zzhang/xar/bin:/soft/java-1.5.0_06-sun-r1/bin:/soft/java-1.5.0_06-sun-r1/jre/bin:/usr/kerberos/bin:/bin:/usr/bin:/usr/X11R6/bin:/usr/local/bin:/software/common/softenv-1.6.0-r1/bin:/home/zzhang/bin/linux-rhel4-x86_64:/home/zzhang/bin:/soft/apache-ant-1.6.5-r1/bin:/software/common/cert-scripts-2-5.rev44-r1/bin:/soft/condor-6.8.1-r1/bin:/software/common/gx-map-0.5.3.3-r1/bin:/soft/globus-4.0.3-r1/bin:/soft/globus-4.0.3-r1/sbin)
Caused by:
        Job failed with an exit code of 1
Cleaning up...
 Done
SWIFT RETURN CODE NON-ZERO - test 061-cattwo
Ben Clifford wrote:
> On Tue, 21 Apr 2009, Zhao Zhang wrote:
>> Warning: -Xmx256M not understood. Ignoring.
> This comes from a change that happened to communicado sometimes recently.
> Modify your ~/.soft file so that you have the line:
> +java-sun
> before @default
> Otherwise, you end up using gcj for java instead of a real java.
