[Swift-devel] feature request
Zhao Zhang zhaozhang at uchicago.edu
Tue Apr 21 11:48:01 CDT 2009
Hi, All
I checked out the swift-0.9rc2 from
http://www.ci.uchicago.edu/~benc/swift-0.9rc2.tar.gz <http://www.ci.uchicago.edu/%7Ebenc/swift-0.9rc2.tar.gz>
And I manually copy it to
~/swift_coaster/cog/modules/swift/dist/swift-0.9rc2/
[zzhang at communicado swift]$ which swift
~/swift_coaster/cog/modules/swift/dist/swift-0.9rc2/bin/swift
Then I started with the coaster-local test: with the following error
message:
[zzhang at communicado sites]$ ./run-site coaster/coaster-local.xml
testing site configuration: coaster/coaster-local.xml
Removing files from previous runs
Running test 061-cattwo at Tue Apr 21 11:45:17 CDT 2009
Warning: -Xmx256M not understood. Ignoring.
log4j:ERROR Error occured while converting date.
java.lang.IllegalArgumentException: Illegal pattern character
   at java.text.SimpleDateFormat.format(java.util.Date,
java.lang.StringBuffer, java.text.FieldPosition)
(/usr/lib64/libgcj.so.5.0.0)
   at java.text.DateFormat.format(java.util.Date)
   at
org.apache.log4j.helpers.PatternParser$DatePatternConverter.convert(org.apache.log4j.spi.LoggingEvent)
(Unknown Source)
   at
org.apache.log4j.helpers.PatternConverter.format(java.lang.StringBuffer,
org.apache.log4j.spi.LoggingEvent) (Unknown Source)
   at
org.apache.log4j.PatternLayout.format(org.apache.log4j.spi.LoggingEvent)
(Unknown Source)
   at
org.apache.log4j.WriterAppender.subAppend(org.apache.log4j.spi.LoggingEvent)
(Unknown Source)
   at
org.apache.log4j.WriterAppender.append(org.apache.log4j.spi.LoggingEvent)
(Unknown Source)
   at
org.apache.log4j.AppenderSkeleton.doAppend(org.apache.log4j.spi.LoggingEvent)
(Unknown Source)
   at
org.apache.log4j.helpers.AppenderAttachableImpl.appendLoopOnAppenders(org.apache.log4j.spi.LoggingEvent)
(Unknown Source)
   at
org.apache.log4j.Category.callAppenders(org.apache.log4j.spi.LoggingEvent)
(Unknown Source)
   at org.apache.log4j.Category.forcedLog(java.lang.String,
org.apache.log4j.Priority, java.lang.Object, java.lang.Throwable)
(Unknown Source)
   at org.apache.log4j.Category.debug(java.lang.Object) (Unknown Source)
   at org.griphyn.vdl.karajan.Loader.main(java.lang.String[]) (Unknown
Source)
   at
(Unknown Source)
   at
   at
(Unknown Source)
   at
(Unknown Source)
   at
(Unknown Source)
   at
(Unknown Source)
   at
(Unknown Source)
   at
(Unknown Source)
(Unknown Source)
Source)
   at
(Unknown Source)
   at
   at
(Unknown Source)
   at
(Unknown Source)
   at
(Unknown Source)
   at
(Unknown Source)
   at
(Unknown Source)
   at
(Unknown Source)
(Unknown Source)
   at org.apache.log4j.Category.info(java.lang.Object) (Unknown Source)
   at org.griphyn.vdl.karajan.Loader.compile(java.lang.String) (Unknown
Source)
Source)
Exception in thread "main" java.lang.NoSuchMethodError: method
java.io.File.toURI was not found.
   at _Jv_ResolvePoolEntry(java.lang.Class, int)
   at
org.apache.xmlbeans.impl.schema.SchemaTypeLoaderBase.parse(java.io.File,
org.apache.xmlbeans.SchemaType, org.apache.xmlbeans.XmlOptions) (Unknown
Source)
   at
org.globus.swift.language.ProgramDocument$Factory.parse(java.io.File,
org.apache.xmlbeans.XmlOptions) (Unknown Source)
   at org.griphyn.vdl.engine.Karajan.parseProgramXML(java.lang.String)
(Unknown Source)
   at org.griphyn.vdl.engine.Karajan.compile(java.lang.String,
java.io.PrintStream) (Unknown Source)
Source)
Source)
SWIFT RETURN CODE NON-ZERO - test 061-cattwo
Michael Wilde wrote:
> http://mail.ci.uchicago.edu/pipermail/swift-devel/2009-April/005167.html
> If you ever need it, swift-devel is archived at:
> (swift-user similarly)
> On 4/21/09 11:17 AM, Zhao Zhang wrote:
>> Hi, Ben
>> It seems that I missed that email. I could not find it in my
>> thunderbird. Could you remind me the address of
>> 0.9rc2 swift?
>> I had a problem receiving emails from Swift-devel list some time ago.
>> zhao
>> Ben Clifford wrote:
>>> You should be testing Swift 0.9rc2, not the latest Swift code from SVN.
>>> So you should find the message that I sent on the mailing list
>>> announcing Swift 0.9rc2, and download that tarball.
>>> Then set your PATH to include the bin/ directory in there.
>>> Don't build Swift from SVN.
>>> The only thing coming from SVN should be the tests/ subdirectory.
>>> You can tell if you are running the 0.9rc2 version by looking at the
>>> version output. It should say Swift 0.92c when you start a Swift run.
>>> You should be running the site tests from a regular linux machine
>>> like communicado. I think surveyor is a more specialised machine
>>> which probably doesn't have what is expected for local coaster
>>> execution.
>>>> I am not clear with my test goals here, am I making sure coaster is
>>>> working on all sites we have, or am I testing the existing coaster
>>>> could be use by any users?
>>> You should be testing how well coasters in 0.9rc2 will work for any
>>> user running on any site.
>>> Imagine a new user arrives, and downloads Swift 0.9. He then picks a
>>> site at random, and tries to use coasters on that site. Will it
>>> work? That is the answer you are trying to find.
>>> Which sites do coasters work on now? Which sites do they not work
>>> on? What are the error messages from the sites they do not work on?
